June 24, 2018, 03:02:01 AM
Author Topic: Engineering Calculators Site  (Read 10939 times)
Offline DrivingMissLazy
« on: March 17, 2008, 08:16:40 AM »
Quote
HighTechRedneck
This link was posted over in the Detroit Diesel yahoo group.  It is the best set of free engineering calculators that I have seen.  Looks like it covers just about everything.
http://www.calculatoredge.com/
« Last Edit: March 18, 2008, 11:08:09 AM by DrivingMissLazy »
Offline H3Jim
Re: Engineering Calculators Site
« Reply #1 on: March 17, 2008, 08:40:49 AM »
wow, you're right, they do have everything.  Great site.
Jim Stewart
Dallas
« Reply #2 on: March 17, 2008, 10:48:07 AM »
Another great calculator site:
http://www.csgnetwork.com/converters.html
an inflation calculator:
http://data.bls.gov/cgi-bin/cpicalc.pl
Metal Calculator:
http://www.mesteel.com/cgi-bin/w3-msql/goto.htm?url=http://www.mesteel.com/info/conversion.htm
Have fun on your run, keep the sunny side up and the dirtyside down, The bugs off the glass and the Bears off your.... bumper.
Offline HighTechRedneck
  • Global Moderator
  • BCM Webmaster
    • Bus Conversion Magazine
« Reply #3 on: March 17, 2008, 11:59:10 AM »
Fascinating.  If it is accurate (and some quick reality checks suggest it is), it very effectively validates my gripe with the Social Security Administration's so called cost of living adjustments.  In 1973 Mom was getting $300 per month.  Based on that calculator, to have the same purchasing power now, she would need to be receiving $1,430 per month now.  But instead she gets $604 now.
« Last Edit: March 17, 2008, 12:11:23 PM by HighTechRedneck »
Dallas
« Reply #4 on: March 17, 2008, 12:24:53 PM »
Mike, one of the reasons I included it was that it is a "dot" gov.
If the rest of the government and the idiots that work there can't agree, what do you think the chances are of getting a "Fair Deal"?
It's also interesting that in the late 90's my EFIL was receiving $625from SS... yes it was, he was also geting Part "a" and Part "b".
To make the story even better, he worked for Jewish Hospital in Louisville, Ky for 13 years, and as a result of his disability from them got $$2992.00/month.
Everytime his check from SS went up, his rent also went up. This usually meant he was exactly even on his section8.
The same apartment building where he lived had the same apartments available for open rent at $348/month. The best part was that those same apartments included cable and the use of the "facilities" (those were the hottub, jacuzzi, weight room and steam room.
When confronting both the apartment building management and the Social Security admin, we were told nothing could be done, it wasn't illegal, don't bother us, "Press One for English", KMA, and best of all.. this isn't really my job, you'll need to contact the PTB for the answer to your question.
Fascinating.  If it is accurate (and some reality checks suggest it is), it very effectively validates my gripe with the Social Security Administration's so called cost of living adjustments.  In 1973 Mom was getting $300 per month.  Based on that calculator, to have the same purchasing power now, she would need to be receiving $1,430 per month now.  But instead she gets $604 now.  Before, just using my estimations, I took the issue to the SSA to see if there had been some kind of error.  They double checked it* and said that it she was getting the correct amount. ::)
* In govt offices, "double checking" means they printed out the account record and simply repeated what it showed.  Not much human thinking goes on in those offices.
Offline NewbeeMC9
  • NewbeeMC9
  • 1981 MC9 8V71, HT 740
« Reply #5 on: April 28, 2009, 08:11:44 AM »
This one is kinda interesting, make sure you have plenty of time when you look at it ;)  THey are starting to link to more commercial stuff but it is usually the recipes and such.
http://www.martindalecenter.com/Calculators.html
