I am considering using PVC 3" pipe as my AC ducts. Anyone have thoughts as to the pros and cons of using this product. I will have the pipe run down the middle of insulation.ThanksGrant
WARNING: I will be the first to admit I don't know diddley about this topic, so this may be a very stupid question...If you run A/C and/or heat (conditioned air) through a plastic pipe, wouldn't you build up quite a charge of static electricity?
Hi Dallas,Not that it matters in this case, because 3" PVC pipe is too small to be used as A/C ducts, but 3" PVC has an O.D. of 3.5" not 4", as you stated.Thanks, Sam 4106
