What HTRN said. I'd add another couple blocks of wood and cross piece to the center to make a handle (or maybe two handles) so you can install it from within the bus by yourself. You should be able to put it through the opening diagonally and then line it up, pull it in tight using the handle(s) and then flip the latches over the edges.
