Author Topic: Americana Frig, not cold  (Read 1934 times)
Offline Kwajdiver
  • MCI-9 "Kwaj Diver"
« on: July 16, 2008, 05:37:47 PM »
My Americana Refrigerator seems to be dying.  It's not keeping the beer as cold as it once did, nor the ice cream.  Is there an adjustment on these units?  A way to check the system?
Model number RM 2852
AC & Gas
Thanks in advanced for the help.
Bill
Tampa Bay
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
Offline NewbeeMC9
  • NewbeeMC9
  • 1981 MC9 8V71, HT 740
Re: Americana Frig, not cold
« Reply #1 on: July 16, 2008, 06:07:55 PM »
easiest first check is to make sure all heat exchangers are getting the appropite air flow, outside and in.
« Reply #2 on: July 16, 2008, 06:26:56 PM »
Bill, you control the temperature on a 2852 by moving the sensor or the theristor on the back of the fridge up or down on the fins  good luck if that doesn't work go www.rvmobile.com or call 1-425-355-1176
  • Global Moderator
  • Nick & Michelle Badame
« Reply #3 on: July 16, 2008, 08:43:24 PM »
Hi Bill,
Are you running it on gas or electric?
If electric, check to see if the element is burning the insulation in it's mounting hole by pulling the element out and inspecting it.
If gas, make sure the unit is venting properly as mentioned above.
Sojourner
« Reply #4 on: July 16, 2008, 10:01:59 PM »
Or if it either way…then it the evaporative system.
Read on about “Cooling unit blockages”:
http://www.rverscorner.com/articles/refer.html
FWIW
Sojourn for Christ, Jerry
Offline Kwajdiver
« Reply #5 on: July 17, 2008, 06:50:12 PM »
Thanks guys,  I'm running on electric.  Will check all this weekend.
Bill
Auburndale, Florida
MCI-9
