Hi, am new to the board and having engine(6V92T)problems with my first bus.I have a slight amount of water dribbling from the right side air box tube,motor is very hard to start . When finally started it seems to run fine,have had a multitude of problems bringing bus home.First the fuel pump,replaced with new,had virtualy no turbo boost,found problem to be disinagrated turbo output hose,replaced it and restored the boost up to around 18-19 pounds ,motor was running kinda hat at around 200 degrees,found radiator to have holes in it ,replacied it tryed to start motor it seemed like it would want to lock at certain points .Finnally got motor running ,water initially blew wa small amount of water out of exhaust conections leading to the turbo then motor ran fine seemed to have full power , let it idle for about 1 half hour temp started to clime back to 200 degrees,shut motor down and tryed to re start which it did revved up engine momentarily at which point it when it returned to idle it stalled .any insight would be apreciated ,thanks
