June 23, 2018, 11:31:40 PM
Author Topic: Main entrance door latch missing part.  (Read 2103 times)
Offline Chariotdriver
« on: August 01, 2008, 04:24:12 PM »
    I have the latch on the main bus door that has decided to break.
 Upon further inspection it looks like the previous owner had rigged it up to open from the inside with
some small diameter galv cable to "pull" the mechanism to draw the bolt back into the door when exiting.
 The Manufacture is  "A.L. Hansen" and I have tried to see about ordering the missing part but with no success on getting a call back, as of yet.
 I may have to replace the entire mechanism to make this work at this point as opening the window to use the outside latch is getting old.
  Any good leads on what to get to be able to replace the entrance door latch?
 This is on a 83 Eagle.
 Thanks for any leads.
 Phil
Phil Webb
Pass Christian, MS
Re: Main entrance door latch missing part.
« Reply #1 on: August 02, 2008, 04:01:01 AM »
Hi Phil,
This is what I use on our Eagle 01.
http://www.pplmotorhomes.com/parts/rv-locks/rv-door-lock.htm
You can also do a search on the net and locate more suppliers.
I bought a new one last year but can't remember who it was. (CRS)
 ;D
Hope this helps,
« Reply #2 on: August 02, 2008, 04:14:34 AM »
 Thanks Paul, I will look mine over to see if that one will work.
 Phil
Phil Webb
Pass Christian, MS
Sojourner
« Reply #3 on: August 02, 2008, 07:30:59 AM »
Chariotdriver....a picture of your latch will greatly help to locate the source.
A. L. Hansen website does not show everything they market in the pass or whatever reason.
FWIW
Sojourn for Christ, Jerry
« Reply #4 on: August 05, 2008, 09:03:51 AM »
Hi Phil,
 ;D
Hope this helps,
  Thanks Paul, ordered one today
Phil
Phil Webb
Pass Christian, MS
« Reply #5 on: August 05, 2008, 09:12:59 AM »
Phil, when you have time go to a truck wrecking yard and buy a door latch from a Pete or KW the RV latches don't hold up and they are expensive I have the same latch as Paul but converting over to the truck latch also a Jeep door latch will fit the hole perfect  good luck
« Last Edit: August 05, 2008, 09:29:56 AM by luvrbus »
