What do you guys do with the exhaust from the Pro-Heat ,Webasto and the Aqua Hot they smell and smoke as much as a generator and exhaust at 500 or 600 degrees and I don't recall ever seeing those with a stack
The location of the muffler makes it more difficult to run the pipe to the side of the coach, as opposed to going up. The only way In can get to the side, is by having it be the lowest point in the bus underside. I'd hate to scrape it off going off road as I do sometimes.
Jack,It is hard to tell from your picture, but it looks like you have a bolt coming through with the nut on the low end of the top hat channel. The PO had done this with our generator and it began to cave the channel in. We had to modify it to return it to a good grip.
