I don't know any thing about inverter/chargers but I know that I need a good battery charger and to have 12 power when pluged in would not be a bad thing either. I don't know if this would be a bargin or too costly to repair.
I am looking at a XANTREX 1500 WATT INVERTER/CHARGER, model # 81-1522-12 (single 120V input, dual 120V output, with circuit breakers 20/15 amp). It has a problem when in inverter mode (off grid) any outlet on the output side showed an hot/netural reverse. But when on grid, all circuits were normal in the pass thru circuit. But they are unsure if it was charging the batteries or not.
Is it repairable and what would it be worth like it is?
I know these are not cheap nor are they really expensive, I am just wondering if I should worry with it or not or what it should be worth?
