BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Framing in the roof hatches on a 102A3 for AC units,tips and pics please
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Framing in the roof hatches on a 102A3 for AC units,tips and pics please (Read 4662 times)
bigtim44
Jr. Member
Red buses go faster!
on:
June 15, 2006, 09:03:23 PM »
I'm going to put 2 roof top AC units on our bus,and fit them where the escape hatches are.I first need to weld up a frame for the 14 inch hole for the AC,then skin over the remainder of the hatch.
I'm sure there are photo's of this being done,Any tips and pics appreciated.
Tim
Logged
Basalt Colorado
1986 TMC 102A3,6V92,Auto 740,conversion in progress.
http://redbusconversion.blogspot.com/
Danny
Sr. Member
87' MCI 102A3 - getting there...
Re: Framing in the roof hatches on a 102A3 for AC units,tips and pics please
Reply #1 on:
June 15, 2006, 09:34:25 PM »
I am getting ready to do the same thing with the same bus. I panned over the windows with .080 aluminum. It seemed think enough to handle the weight with supports. I am going to use Sikaflex for fasten the metal to the top. I am using this same product for the windows and it works great. If you place a cross brace for the other end of the AC the existing brace can take care of the other side. That is what I am planning on doing.
Good luck,
Danny (Tennessee)
Logged
I have heard it said, "life comes at you fast". I didn't know it would be in the shape of a bus :-)
gumpy
Some Assembly Required
Hero Member
Slightly modified 1982 MC9
Reply #2 on:
June 16, 2006, 04:50:55 AM »
I moved my rear hatch forward, and covered the old hole. Not quite the same as what you're doing , but close. There are photos located in the conglomeration of photos on this link:
http://www.gumpydog.com/bus/Uplink/uplink.htm
About midway down the page.
Logged
http://bus.gumpydog.com
- "Some Assembly Required"
86neoplan
Newbie
Reply #3 on:
June 16, 2006, 05:02:40 AM »
This subject is very interesting to me, as I will be doing the same thing. I was wondering how I was going to do this as well...
shawn
Logged
Proud single custodial dad to a wonderful 14 year old son, Owner of a 1986 Neoplan 26' transit Bus AN408, Great weekender...Lots of work to come on this bus, can't wait to get her done! 8.2L with a Allison AT545...
Hero Member
Reply #4 on:
June 16, 2006, 08:07:41 AM »
Tim- Since the roof hatch is already reinforced, just use the proper thickness of wood to frame it down with angle iron supporting the ends screwed into place. I realize that welding is always the best way, but remember, the bus doesn't ride like a truck, nor are you going to put hundreds of thousands of mile on the bus. I have three roof A/C's. I cut the holes right up against the roof bows and then just framed it in with 1x2 fir strips-like I used in the entire bus screwed to the support beams. With the foam in place, the A/C's don't bounce at all (and I've been over some bumps and watched the A/C's [when the road was clear]). Doing it with wood is the easy way and it works, welding in a new frame is the best. You decide. Good Luck, TomC
Logged
David Anderson
Hero Member
just outside San Antonio TX
Reply #5 on:
June 16, 2006, 12:45:29 PM »
Like Tom said, I framed mine with wood. Make sure it is slightly higher that the rest of the roof to avoid any puddling. I removed all the hatch framing, and I framed the hole first then glued and riveted a sheet of aluminum over it and cut out the hole when ready to install the AC. This is on an eagle, so your's may be slightly different. The concept is the same, however. I believe my installation required a 14"x14" hole.
If you notice the green primer paint at the end of the lumber, I welded in 1.5"x1.5" angle to screw the lumber to the frame.
David
Logged
bigtim44
Jr. Member
Reply #6 on:
June 17, 2006, 07:15:45 AM »
All good info ...thanks
Tim
Logged
Basalt Colorado
86neoplan
Newbie
Reply #7 on:
June 17, 2006, 05:21:28 PM »
yes, thanks for the info. I only have 2 to install, so I think I will go the wood route, since I dont own a welder.
shawn
Logged
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
