Author Topic: Pex plumbing lines? Size does matter!  (Read 6304 times)
Re: Pex plumbing lines? Size does matter!
« Reply #30 on: August 24, 2008, 02:33:40 PM »
Jack, I am not trying to give you a bad time about the Pex tools people just tell me all the time that you cannot do this with Pex a product that was design to be crimped.Me I would not use sharkbite or any other push on fitting with Pex but that is my way. Pex is good stuff and easy to work with
« Last Edit: August 24, 2008, 02:46:35 PM by luvrbus »
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
« Reply #31 on: August 24, 2008, 04:10:22 PM »
No problem.  It is kinda a standing joke.  Everytime I see or hear about a new tool, I seem to think I should add it to my tool inventory.  My wife tries to use reason and explain to me that I really do not need every tool that is made.  Jack
Offline Busted Knuckle
« Reply #32 on: August 24, 2008, 07:09:42 PM »
Jack,
Boy that right there is hard to swallow, & just makes me wonder! Now I ain't never met you and Paula, but I have met alot of people who have. And they all say how great ya'll are, and on and on.
And I do really know Paula is a great person, but now hmmm ya really got me second guessing here. I mean
"My wife tries to use reason and explain to me that I really do not need every tool that is made."
That is just really hard for a tool junkie like me to take! I think I need to go out and cry with my tools!
I guess it'll be alright after all you guys hve been a great couple all these yrs! And love must have something to do with it, but I feel deeply for ya! Cause busnuts needs tools & LOTS OF 'EM! ;D  BK  ;D
Offline NewbeeMC9
  • NewbeeMC9
  • 1981 MC9 8V71, HT 740
« Reply #33 on: August 24, 2008, 07:58:21 PM »
Jack, Next time try , Cause your haircut only cost ______ dollars and the tool makes you feel better about yourself :D
Luvrbus,  i like the crimp, but i knew i would be taking stuff a part again and again as i fix different things so iI used the push fittings on the bus,  my last house had the crimp fittings( but i had somebody do it because i wanted it done quicker than me doing it and old galvanized was being replaced in a crammped, extreemely dusty crawlspace).  Plus i didn't need may fittings for the bus so it was cheaper than tool.
All these tools and fiittings seems like a good article for BC MAG  with pic otools bing used and fittings etc
Offline David Anderson
« Reply #34 on: August 30, 2008, 01:24:49 PM »
This relates to PEX, so I figured I'd post it here and bring the thread back to the top.  I just watched an "Ask This Old House" segment on PBS where Richard Trethewey went to Raleigh NC to work with a plumber who makes a living replacing polybutylene pipe in houses.  That is all this company does.  Richard briefly explained the history of Polybutelene's origination as the great plumbing solution of the 1970's.  Here we are, 30 years later replacing all this cracking and leaking poly pipe and replacing it while class actions lawyers sue for millions and consumers get a $5 coupon on their next purchase or something or other the bankrupt manufacturer now makes.
The segment had Richard and the plumbing contractor show some closeup views of the cracking pipe and the leaking fittings.  It is mostly the crimps that failed allowing leakage at tees and ells.  The crimps look alot like the copper and stainless crimps we see today on PEX fittings.   What will keep a repeat of this in 30 years in all these homes?   I do like the fact that PEX is mainly done with home runs and fittings are minimal and isolated at the manifold and the fixture.  If the pipe lasts for 50+ years then replacing fittings will be much easier if that is the weakest point in the system.
The house profiled in the segment had fittings in the ceiling, walls, and crawl space.  They had so much of the sheetrock removed.  It must have been a huge expense.   The system was repaced with all CPVC, not PEX.  I guess just the choice of the local plumber, or perhaps he doesn't trust PEX.  No explanation was given, though I know Richard Trethewey loves to use PEX.
Just a thought to bring up.
David
