MCI 102A3 42′ Hoffman Coach Conversion
• Detroit Diesel 8V92 engine
• Allison HT740 automatic transmission
• 18K Yanmar Generator 900hrs
• Estimated 190,000 miles; mechanical odometer is not operating correctly, but complete bus history and records available
• Extensive documented maintenance history
• Major mechanical refurbishment completed
• Updated and modernized interior
• Modernized air-conditioning systems
• Newer tires (2024), suspension, steering, brake, and air-system components
• Original MCI Parts and Maintenance Books
This is a beautiful Hoffman Coach conversion with original Imron (aircraft) paint by StarJet of Ohio. The paint remains in mostly excellent condition, and the coach presents exceptionally well inside and out.
I contacted Hoffman Coach directly and shared photos of this coach. The company is still in business, now run by the founder’s son, who remembered this specific coach.
MCI Coach Corp has complete service and parts center available for all MCI coach owners. www.mcicoach.com 24hr emergency service 800 241-2947 Technicians 866 624-2622. Parts 800 323-1290
I am the third owner and purchased the bus in 2022 for $55,000. The original owner kept it for approximately 30 years, and the second owner owned it for about six years.
During its time in Minnesota, the bus was stored entirely indoors. It is currently kept in covered storage. For many years, the coach spent approximately six months each year in Arizona before returning to Minnesota, averaging about 5,000 miles per year over its first 30 years.
I have driven the bus nearly 10,000 miles over the last four years, cross-country travel from one side of the country to the other (including several times over the Rockies).
The complete history of this coach is known. C&J Bus Repair in Bloomington, Minnesota, maintained the bus for approximately 36 years before I purchased it. Since then, extensive maintenance and restoration work has been completed.
Much of the recent work was performed by Scott Crosby at Bus Grease Monkey in Tennessee. I have receipts for work completed during my ownership, totaling approximately $70,000 over the last four years. Owners rarely recover their full investment in coaches like this, but this level of refurbishment is necessary for reliable cross-country travel.
Recent work includes replacement of all shocks, hoses, belts, air bags, thermostats, the air dryer, differential pinion seal, oil pan gasket, water pump, and main 8D batteries. Regular engine oil, oil filter, fuel filter, transmission oil, and transmission filter service has been performed. The coach also has newer tires (2024). The radiator was flushed, and all eight brake drums were removed and serviced, including races, bearings, pads, and king pin work. All air brake lines were custom-measured, cut, and replaced, providing a major safety upgrade. Additional updates include a new Raritan 12-gallon marine water heater, upgraded Honeywell components for the three coach air-conditioning units, and preventive maintenance on the over-the-road Cruise Air system, including recharge.
Both front windshields have been replaced with tinted glass. The front carpet was upgraded to new flooring, all interior window shades are new, and the furniture has been reupholstered and modernized. Sound and heat insulation were added to the generator compartment. Pull cables were installed on both front sides of the coach for easy access to the air-tank drains. All running lights, brake lights, fog lights, turn signals, and headlights have been serviced and are working properly, and the rear brake-light harnesses have been replaced.
If you are looking for a road-ready vintage coach, this is it.
$84,000
