BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
QUESTION FOR TOMC
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: QUESTION FOR TOMC (Read 2267 times)
mccarlk
Full Member
1967 mci 5 8v71 auto
QUESTION FOR TOMC
on:
November 11, 2008, 04:57:20 PM »
hi tom , where did you run your oil drain from the turbo, also do have any pics of the way you mounted your turbo, thanks
Logged
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
Hero Member
Re: QUESTION FOR TOMC
Reply #1 on:
November 12, 2008, 08:42:47 AM »
Don Fairchild used an unused block plug in the crankcase above the oil line for the oil return. Hopefully this picture came through. Good Luck, TomC
Logged
Hero Member
Reply #2 on:
November 12, 2008, 08:52:57 AM »
I apologize for the quality, don't quite know what happened-the picture was taken with a 10.2mp camera. Good Luck, TomC
Logged
Songman
Guest
Reply #3 on:
November 12, 2008, 12:01:33 PM »
I'll see if I can get a better picture if needed, but it is like Tom said. Don just always picks an unused port that is low on the side of the block and pipes the turbo oil back into the engine there. It goes right back into the oil pan and ready to be filtered and used again.
Logged
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
QUESTION FOR TOMC
