Author Topic: Inverter and converter  (Read 3480 times)
Offline Lin
  • 1965 MC-5a
« on: November 17, 2008, 08:52:37 PM »
My current set up is with two house batteries and a converter.  I got a Trace 2512 inverter a while ago and never installed it.  I now bought 3 135 amp hour AGM's and will soon probably take up the job of relocating the battery bank, installing the new batteries, and installing the inverter.  My question deals with what to do with the converter.  It works fine, and as you know, takes care of all 12v needs when plugged in.  I have been warned the the chargers in these converters are prone to overcharge battery banks, and I certainly don't want to do that with the AGM's.  So my options are to just unplug it and leave it available for some future need, remove it entirely, or use it as a power supply, but block its access to charging my batteries, possibly with a diode.  What suggestions do the masters have?  I sort of like the last option if it is feasible, but wonder if I am missing some problem that it would cause.  I figure that if it would work, the batteries would be charged by the Trace when plugged in without constantly being taped since the converter would supply the 12volt.  Obviously, the converter would have to be set up to only work when there was shore/generator power.
  • Global Moderator
  • Nick & Michelle Badame
Re: Inverter and converter
« Reply #1 on: November 18, 2008, 03:43:06 AM »
Hi Lin,
I always like redundency... i would isolate it and keep it for future emergency's if you have the space.
Other then that, don't take a chance in overcharging your AGM's or having it ruin your inverter.
Good Luck
Offline Tenor
    • Tenor Clock
« Reply #2 on: November 18, 2008, 04:40:17 AM »
This is probably a long shot, but some inverters now have very good battery chargers.  What model do you have?  Something else to consider - inverters are expensive, why not reduce the time you use the inverter and use the converter with it's own battery when you know you have shore power?  Just use a 3 way switch to select 12V power from the inverter or the converter.  Good luck!
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
Offline JohnEd
« Reply #3 on: November 18, 2008, 12:20:16 PM »
Unplug the converter and leave it in place as a backup.  When you use the converter you should have your bats isolated from the house and not being charged unless you select that.  I guess that would cover a "inverter" total crash.
Run your house off the batteries full time.  With no AC it will deplete the bats as God intended.  With AC the inverter will supply dc to the bat circuit and the house.  Is what was recommended to me.  Now my question is by doing this will I cause the inverter to "see" a low battery and keep the charging voltage at 14.5 volts DC even if the bats are topped off and in need of a trickle charge?
Offline Lin
  • 1965 MC-5a
« Reply #4 on: November 18, 2008, 04:19:30 PM »
That's the trouble, I don't know what happens.  I once had a set of AGM's on another coach that was kept plugged in for a long period of time.  The coach had a three stage charger, so I though all would be alright and maintenance-free.  After a couple of months, the batteries were ruined.
Offline white-eagle
« Reply #5 on: November 18, 2008, 06:36:07 PM »
i keep the batteries on for powering the 12v in the coach.  the old converter is available, just needs to plug in and move a wire.  but i now power all the 12v lights, appliances with the batteries.  we have a 2012 2000w xantrex w 6 gc 6v batteries.  seems to work so far.
Tom
Offline JohnEd
« Reply #6 on: November 18, 2008, 08:06:35 PM »
Man,
If you are running your 2012 and you have a 12V load on....what is your battery voltage?  I think 14.5 for charge and 13.4 for maintain and 12.6 for bats alone.  I am ready to install my 3012 and that info would be helpful.
Offline JackConrad
  • Orange Blossom Special II
« Reply #7 on: November 19, 2008, 04:34:15 AM »
Was the 3 stage charger setting re-adjusted to match the AGM batteries.  I seem to recall that somewhere I read or heard that AGMs require a different charge profile?  Jack
Offline white-eagle
« Reply #8 on: November 19, 2008, 06:19:37 AM »
my inverter does have a different charge profile that i would have to change to for agm's.
Tom
