Author Topic: inverter installation  (Read 3466 times)
Offline circusboy90210
  • Chat Banned
« on: November 18, 2008, 03:08:04 PM »
Was wondering how big of an inverter can I safely run on a 6.2 diesel? ???sorry forgot to mention brand new 100 amp alternator & no ac.
Offline Melbo
  • MC8 under construction
Re: inverter installation
« Reply #1 on: November 18, 2008, 05:51:07 PM »
I don't know how big a light bulb will a solar panel light
How fast will a car go
How big is big after it is small
I don't understand your question please rephrase it.
Thank You
Mel
Offline white-eagle
« Reply #2 on: November 18, 2008, 06:25:07 PM »
it's more like how much inverter do you need, but i'm quite sure you can charge your batteries with the generator you listed.  a 2000 or 2500 can charge up even with only a 15amp shared shore power, so the generator should be fine.  i've set my 2000w inverter/charger to use 15a shore power so that i can keep computers, refrig, and tv on without blowing a breaker.
does that help?
Tom
Offline JackConrad
  • Orange Blossom Special II
« Reply #3 on: November 19, 2008, 04:28:09 AM »
Depends on big the alternator is and how long you want to run it.  Jack
Offline Lee Bradley
« Reply #4 on: November 19, 2008, 08:41:06 AM »
With a 100 amp alternator at full output, you get about 1400 watts. So you could support a 1400 watt inverter continuously assuming no other loads. Generally you use a large battery bank to store energy to supply the inverter for less than full time use and recharge the bank while the engine is running. As with any bank if your withdrawls exceed your deposits, you end up broke.
Offline kyle4501
  • NEWELL in South Carolina
« Reply #5 on: November 19, 2008, 12:59:02 PM »
What is the duty cycle of the new 100amp alternator?
What are you wanting to operate?
What is the capacity of your battery bank?
  • Chat Banned
« Reply #6 on: November 19, 2008, 06:14:15 PM »
only 2 truck battery's .
what is duty cycle? operating ice cream freezer?(small unit ,& maybe another)i think the batery's are 800-1500 cranking amp just remember buying heavy uty batteries 2 cold 22 check right now.
Offline Melbo
« Reply #7 on: November 19, 2008, 06:21:53 PM »
Hey CB now we are getting somewhere
the duty cycle is how long you can run the alternator at full load
Like 50 percent duty cycle means that you can draw 100 amps for a surge at start up but the more realistic number would be 700 watts for continuous load.
HTH
melbo
