hey nick,agreed. i actually had the same idea in mind. since i am making this more of an entertainer coach, the front 1/3rd or so of the bus is going to be couches. i am going to be making the couches myself, so what i was going to do is construct them out of plywood, and then get some good cushions custom fit and upholster them myself. with that being said, i was thinking of running the ducting along the bottom of the couches, with maybe 3 vents or so on the bottom underneath them, then run them up and over the bunk area which is about 2/3rds of the way back, with about 2 vents coming out on top, and then go right back down to the rear lounge which is going to have a u-shaped couch and basically do the same as the front lounge, and have 3 vents, one on each side of the u-shaped couch, coming out from underneath the bottom.now the material you used for your ducting....is this something i can purchase from you, and if so how much does it run? or is this something i should purchase elsewhere, and if so, where?thanks Nick!
