Author Topic: Best Bus Value for the money?  (Read 10385 times)
Offline NEO/Russ
  • NEO/Russ
  • Jr. Member
« on: January 09, 2009, 09:16:42 AM »
My daughter lives in the MSP area and has a contact that is trying to help his church buy their own bus.  They want a full sized to take groups to several areas away from the twin cities, not a schoolie or airport shuttle.  They need an automatic for various drivers, but otherwise what is most important is very good condition inside and out and dependable.
I've gotten away from buses and turned to big HDT/fifthwheelers, but I know this group can suggest a few things.
   * Is there a brand/model that would be good to look for in the $15-20k range?
   * In the western burbs of Minneapolis(or the city area in general) is there a
      reputable dealer?
   * In the western burbs of Minneapolis is there a good service dealer/mechanic
      for inspection or repairs?
Thanks for all feedback and have a great '09.    Russ
Well no longer a bus nut, but over the years I learned a lot here and still come back to see what I can apply to the conversion of my KW T2000 for hauling my Teton fifth wheeler.
Offline WEC4104
Re: Best Bus Value for the money?
« Reply #1 on: January 09, 2009, 09:54:31 AM »
I am going to throw a few questions your way to help zero in on helping with recommendations:
1) Any feel for the annual mileage that will be put on this bus?
2) Will the bus be used more for day excursions, or multi-day trips? (cargo space underneath?)
3) On board bathroom facilities needed/desired?
4) Does the usage lean more toward the types of trips where every seat will be occupied (ie: number of seats important), or extended trips where maybe 60-70 % of the seating is actually used.
5) Will maintenance be handled by a commercial shop, or church members?
Offline NEO/Russ
  • NEO/Russ
  • Jr. Member
« Reply #2 on: January 09, 2009, 10:17:55 AM »
Exactly what I was looking for to qualify the purchase.  I will forward and get back to you next week - thanks.
Offline belfert
« Reply #3 on: January 09, 2009, 10:52:23 AM »
C&J Bus Repair is the place to go in Minneapolis for bus repairs and inspections.  952-881-0034.  I get my yearly oil change, lube job, and inspection there.
JD there also sells buses from time to time, but mostly well beyond the church's budget.
Offline pickpaul
  • New Bus Not
  • New Bus Not
« Reply #4 on: January 09, 2009, 11:39:26 AM »
I saw this bus via Oodle yesterday and thought it looked like a sweet bus for $15k
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180319473794&category=6728
Cheers, Paul.
Offline Sean
  • Geek.
    • Our Odyssey
« Reply #5 on: January 09, 2009, 01:50:57 PM »
Russ,
You might pass along to your daughter that those "various drivers" who need automatics will also each need a class B CDL with Passenger and Air Brake endorsements.  The coach will also need to pass DOT inspection and be registered with the FMCSA.
It is a popular misconception among churches that they are somehow exempt from this requirement, particularly if the driver is a volunteer.  The FMCSA and DOT consider a church a commercial enterprise and all the CDL and commercial inspection and weight rules apply, along with log books and hours-of-service -- even if the driver is an unpaid volunteer.  This is inviolable if the coach is driven across state lines, as it now becomes a matter of federal law.  If it never leaves the state, then MN law applies, which may be more lax.  In any case, they should definitely do the research.
All enforcement agencies are giving this issue much more attention since a busload of church members ran off the road a few years ago behind an unlicensed (wrt CDL) driver:
http://www.nacba.net/PDF_FILES/Fatal%20Crash.pdf
Ironically (to you and me, at least), the bus involved in that case was a Neoplan.
cody
« Reply #6 on: January 09, 2009, 02:45:40 PM »
Excellent point sean, one of the churches in this area fought that battle out locally and lost, they were under the impression that because they were a church they were exempt but when they got pulled over by an MDOT officer they not only couldn't produce a log book or a CDL, the bus was found to be in a sad state of repair and was redtagged by the officer, the bus had to be towed from the stop and the church was forbidden to drive the bus until a long list of safety and mechanical violations were corrected, needless to say a legal battle followed with the judicial ruling being that when the church decided to become a motor carrier they also took on the responcibility of meeting the legal requirements of operating as a motor carrier, they paid the fines, court fees and sold the bus, interesting side note, the attorney they had retained to represent them in court now owns the bus and is converting it to a camper. thats how I became aware of it, I piled some sawdust in and about it lol.
Offline Tenor
    • Tenor Clock
« Reply #7 on: January 09, 2009, 03:16:10 PM »
I have heard that insurance for this type of use is VERY expensive.  Probably something else the church should look into before purchasing too.
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #8 on: January 09, 2009, 08:38:52 PM »
Russ -
At one point in time, the large church I was a member of seriously considered buying an MC-9, for exactly the same reason's your daughter's friend's church is doing.  One of the committee members looking into the project was a conservative CPA, and he asked the important questions, some of which have already been covered here.  But the questions he asked that REALLY got their attention was related to how much the vehicle would cost them on a yearly basis, vs chartering a coach from a local, reputable charter outfit, based on the number of projected trips.
Guess what?
It was cheaper to charter than to own - and with none of the associated headaches!
Suggest to your daughter that her friend explore the same comparisons, especially with a volunteer organization.
OTOH, if the church is big enough, and the numbers pencil in that it's less expensive to own their own, then suggest the church also HIRE somebody to oversee the transportation dept.  (Then add in that salary package into the operating cost, too!)
Offline lostagain
« Reply #9 on: January 10, 2009, 07:05:38 AM »
I am the volunteer driver/mechanic for our local junior hockey team's bus.
One more consideration is very important: the moral and legal responsibility/ liability of operating your own bus. Your organization has to ask themselves: what if a volunteer driver puts it off the road one night and injures or kills somebody? A part time volunteer driver is never as good and confident behind the wheel as a full time professional with a charter company.
In our case, the closest charter bus co. is 70 miles away, so it would be too expensive to charter. But if your church is in a city, tell them to charter when they need a bus. The liability is born by the commercial bus company, not the church and the volunteer driver.
That is worth thinking about...
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Offline belfert
« Reply #10 on: January 10, 2009, 10:39:29 AM »
Quite a few "professional" drivers are no more than steering wheel holders these days.  (There are still plenty of good ones out there too.)
I suspect any volunteer driver has a greater sense of responsibility to his/her passengers and will take less chances especially if his/her family is also on the bus.  Any volunteer willing to undergo the training and testing for a CDL is putting a pretty big committment into driving a church bus.
That said, I agree with others that a charter will most likely be less expensive in the long run.  If a church will run a bus multiple days a week to justify their own bus can they find enough qualified volunteers or will they need to hire drivers anyhow?  One thing that does come up with charters versus owning is who pays for everything?  If church groups have to pay for a charter themselves they may not go, but if the church owns a bus and pays the insurance and repairs then groups are more likely to go if they pay fuel and tolls only.
Offline WEC4104
« Reply #11 on: January 10, 2009, 12:23:06 PM »
If the church already has members who are experienced, professional CDL holding drivers, that is one thing. But if the intent is to have a few folks go out and take their CDL certifications, that is another thing.
I am picturing the church coach being used 1-2 times a month, with a pool of drivers.  Much as they may care about their families sitting in the back, you still have drivers up front that have limited hours of experience, and only get to drive a few times a year.  There are good and not-so-good proffessionals, just like their are good and not-so-good volunteers.  I'd take my chances with the professional that has greater experience and miles under their belt.
Offline NJT 5573
« Reply #12 on: January 10, 2009, 01:08:51 PM »
The big insurance coverage on my Eagle as a motorhome is under $600 a year. $50,000 collision, $1Million Liability and same uninsured motorist. For a commercial bus its around $6000 a year for comperable coverage.
I believe that if I truely wanted to donate my services on occasion to my church for no charge, my insurance would be binding. However if I were to allow them to pay for some fuel or other costs and something happened my insurance could skate on the injuries.
I have had to sue my insurance before to cover uninsured/underinsured motorist and would want to be sure that everything was proper on my end to avoid losing.
I have been in the freight end of the transportation business all my life,(40 Years). I have rarely driven passengers, (a couple years in college as a work study program) but basically, I do not like the responsiblity that goes with being the one that gets people injured or killed. Its alot more relaxing to haul freight and easier to sleep at night.
I see no circumstance that I would turn any driver loose with passengers of any kind that did not have a CDL, a drug test in my file, an app for employment,(Verified), a 10 year copy of their PDL and CDL (A clean one too), at least 100,000 miles, (Thats not much) all weather experience with a bus and a P endorsement, not to mention the log book and a Prorate/Apportioned Plate for the Vehicle, (Prepaid Annually) that covers each state the coach will operate in.
Thats not all, but it is probably enough to keep the Pastor out of jail.
Offline superpickle
« Reply #13 on: January 10, 2009, 01:21:14 PM »
Russ,
Aside from the "Pray it dont breakdown Miant program"   I have looked at a few "Church" busses and Found them Sadly lacking, Mushy brakes, leaky air lines, badly worn tires.. I wont consider a CHURCH Anything again..
Support Global Warming:
Drive an SUV.
Offline David Anderson
  • just outside San Antonio TX
« Reply #14 on: January 10, 2009, 02:05:45 PM »
RJ hit the nail squarely on the head.
We had a sister church in our association that bought a bus for about that price, promptly blew an engine on the first ski trip.  After rebuilding it,  then the AC went out.  After rebuilding that, the bus was sold for less than they originally bought it.  It nearly broke the church financially and left some very hard feelings among some of the members.   From that experience I think it is better to charter a professional.
If they are determined to buy then figure the expected annual mileage and ask a bus company what they would expect that annual cost may be.   It may take your breath away.  Obviously your mileage will be much less than a bus company, so the actual cost will be much more per mile than a high mileage bus company.   They could give you an idea on fixed cost just to own even if the bus is parked behind the church all year.
David
