Author Topic: brushes in evaporator motor on mci 8  (Read 1907 times)
Offline artglass
  • Jr. Member
« on: January 14, 2009, 12:45:09 PM »
 any one had any expierence on installing brushes on the evaporator motor on a mci 8, the 7 book says you have to install them and adjust them using a amp meter , the company i bought the coach from says they just put them in, any one don this before?thank in advance kevin
  • Global Moderator
  • Nick & Michelle Badame
Re: brushes in evaporator motor on mci 8
« Reply #1 on: January 14, 2009, 03:36:44 PM »
Hi Kevin,
DC motors are sometimes just that simple.
One thing to look for while you have the brushes out, look for play in the shaft at the bearings. [up and down play]
If there is any play, this may be the cause of your brushes wearing out and at that point you should look for a replacement
or send your motor to a rebuilder.
Good Luck
Offline Busted Knuckle
« Reply #2 on: January 14, 2009, 04:00:40 PM »
Kevin we just change them! But is a particular coach starts going through them more often than average than the other coaches then we look at why like Nick said! Very rarely a problem though, usually just worn from normal use! FWIW I HTH! ;D  BK  ;D
