Author Topic: What is this items item?  (Read 6177 times)
Offline MattC
  • Recycled DART Bus 8284
« on: January 16, 2009, 04:15:30 PM »
I have a 102 in my driveway and am perplexed at the function of this device. The brass plugs are dead center just below the windscreen on about the same level as the wipers.
I've asked around a bit.  Some folks (no names mentioned) thought it was an attachment point for a moose lure.  The most plausible answer seemed to be it was a plug for where the door release would be on an MC8.
I tried removing it but the plug is 19/32 or some such, not a standard SAE or Metric wrench.
MCI 102A3 / 6V92 / HT740
Camping in our House LOL
WL7CQH
Offline Ace
Re: What is this items item?
« Reply #1 on: January 16, 2009, 04:23:40 PM »
Could it be where an optional windshield washer may spray from?
Ace
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #2 on: January 16, 2009, 04:54:17 PM »
Port for airing up the coach?
Offline busing704
« Reply #3 on: January 16, 2009, 05:28:53 PM »
It is where the T handle for the door release was. Mine is steal there.102A3 1986
Offline MattC
« Reply #4 on: January 16, 2009, 05:32:05 PM »
On this rig, the valve for emergency air to release the brakes is located in the bottom door which is the windshield washer fluid / horn compartment.  However I was concerned about it being air as well.  LoL.
WL7CQH
Offline Tenor
    • Tenor Clock
« Reply #5 on: January 16, 2009, 06:39:58 PM »
Ever watch a Looney Toon's cartoon where the protagonist (Bugg's Bunny) looesns a single bolt on any vehicle (a bulldozer comes to mind) and the whole thing falls apart?  Well guess what you found!  ;D  From now on, that bolt shall be technically referred to as the "Bugg's Bolt".  ::)
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
Offline junkman42
« Reply #6 on: January 16, 2009, 07:07:01 PM »
Matt, If You remove said plug and You hear a ticking sound start  run and be very,very scared.LOL John
Offline MattC
« Reply #7 on: January 16, 2009, 07:18:26 PM »
Glenn
GADZOOKS!  I didn't know MCI was a subsidiary of the ACME company!  ;)  I feel like a macaroon.
WL7CQH
Offline Dreamscape
  • Dreamscape
  • Global Moderator
« Reply #8 on: January 16, 2009, 08:48:40 PM »
Oh so that's the "Bus Bolt" I have heard being mentioned so much. I always wondered where it was, now I know! ;)
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #9 on: January 19, 2009, 12:48:40 AM »
Matt -
Does your MCI's front door open by a toggling a switch on the dashboard?
If so, the mystery of the "Bus Bolt" is now solved!
On the "A" series coaches that had a manually operated door mechanism, there was a "T" handle that came out thru that spot to release the mechanism from outside.  Similar to the plunger on the front of earlier MCIs (GMC's too, for that matter.)
Offline junkman42
« Reply #10 on: January 19, 2009, 07:19:42 AM »
RJ, is it possible that the busbolt is a support device for the busnut inside?  John
Offline busshawg
« Reply #11 on: January 19, 2009, 11:53:15 AM »
I'm with Busing, T handle for the door relaese. Mine has a big button , knob or what ever you want to call to to unlatch the door from th eoutside there, looks like your is plugged with that bolt.
Have Fun!!
Grant
