Author Topic: turbo problem !!  (Read 3255 times)
Offline rdbishop
  • '68 MCI-7 892T, 740 Richard & Missy - Texas
turbo problem !!
« on: July 23, 2009, 09:57:23 AM »
Help guys,
My turbo has a broken fin on the exhaust side that is causing vibration and fuel all over the toad. I have a 8-92 turbo # 8101,440hp. Can I put a 475hp turbo #8511 to make the last 1000 miles home,which I have, or limp home with what I have?
Re: turbo problem !!
« Reply #1 on: July 23, 2009, 10:10:21 AM »
You sure can Richard will be a little more smoke on take off but it will work that turbo is used on a bunch of different hp rating only the A/R is different Good luck
Richard your part number for the 8101 from DD should be 5101513 with a A/R of 1.60 FWIW that turbo was used in seventies for the 8v92 TA green block. with the raw fuel I would be concerned.
Offline Zeroclearance
« Reply #2 on: July 23, 2009, 10:14:42 AM »
The TV8511 is a larger turbocharger>is it from a Detroit?   Do you have the actual part numbers?  1.23 A/R on the exhaust turbine housing side?
How did you lose a turbine blade?   Was there work done on the engine recently?   If you continue to drive your bus, you will have a similar situation that Sean has recently had.
Do you have time to rebuild your existing TV8101?   The TV8511 is a nice turbocharger depending>post the part numbers.
Offline Sean
  • Geek.
    • Our Odyssey
« Reply #3 on: July 23, 2009, 10:26:16 AM »
Based on extremely recent experience, I would advise against driving 1,000 miles on an imbalanced turbine.  You will be better off putting the other turbo on, or, better yet, get a new turbine put on the one you have.
Also, I would make a best effort to figure out how the turbine got damaged before putting a fresh one on.  If you are spitting bits out of the manifolds, you need to fix that first.
Offline rdbishop
« Reply #4 on: July 23, 2009, 11:21:18 AM »
the turbo is a garrett tv 8511  p/n r8927027  s/n v 5501 bd107 and came off 8-92. this was on the inlet- m 24 a\r .61 b.o.  the exh just had garrett on it
The reason it lost a fin was I dropped a valve in cleavlen, ohio. I was towed to canton, ohio to a detroit dealer where a head was replaced engine cleaned out,etc. They didn't have a turbo to replace mine and of course on a friday afternoon. Said I could wait till tuesday or so to get one or drive mine, so we left. this 8511 has no play so I'm going to put it on.
Offline Don Fairchild
« Reply #5 on: July 23, 2009, 11:33:48 AM »
Rd;
The number will be stamped inside the exhaust flange. As Zero said it is a bigger turbo and will move more air, you can change the hot housing ( H H ) to help with your low end and take away some of the smoke. You can also take the throttle delay off and go to a fuel modulator. What size air filter do you have, 7" or 8" 7" is fine for 440hp but 500hp.
Don
« Reply #6 on: July 23, 2009, 11:41:18 AM »
Richard, you know how to contact me if I need to ship you parts    good luck
