Author Topic: Air Beam Leak Repair  (Read 25279 times)
Offline Larry O
« on: April 11, 2006, 08:09:58 AM »
I have a significant leak on my drivers rear side air beam.  I posted this on the "old" board and got a couple of replies.  The concensus is that it would be better to convert the air bags than to weld the air beam.  Unfortunately, I was not online for a few days and now the postings aren't available and I need a bit of clarification.
One of the posts advised to replace the air bags with "rolling lobe airbags".  Can someone shed some light on these types of airbags or preferrably on the whole process of bypassing the airbeam.  Also, any suggestions of suppliers of what I will need would be helpful.
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
Re: Air Beam Leak Repair
« Reply #1 on: April 11, 2006, 09:28:36 AM »
Hi believe Rich @ International Bus Parts carries the air bags.  He may even be supplying the air bags for my current air-bag replacements.  He is a good guy, and regular MAK advertiser.  His web site is : http://www.1800intlbus.com/
Phone is : 800-468-5287
Hope this helps,
Phil
Offline JohnEd
« Reply #2 on: April 11, 2006, 03:08:57 PM »
Folks,
I have read a lot of posts on the air beam problem in the past couple of years. (I am NOT an expert.) What I keep hearing from the people that have deleted the beam is that the suspension then becomes harsh.  The guys that go to the rolling lobe have all said that it is "close" to being as good a ride as the "air beams".  One guy said that the inside of the air beam was rust free and required no work.  Apparently the things rust through from the outside top only and can only be repaired by welding a new piece of plate to the top of the beam and doing it with care.  They seem to rust through due to road dust and dirt collecting on the top of the beam.  From the pictures I have seen it is true that you can only get to the top by removing the floor above the beam.
Now for my question to the board:  Is it true that the air-beam ride is superior?  Can the top of the air-beam be accessed through a hole cut in the floor and can that hole be properly repaired?  Would it be prudent to coat the top of the air-beam with epoxy fiberglass while the thing is exposed during a floor ripout.  They all seem to get ripped out regardless and that is another question.
Thank You
Offline Ross
    • www.newindsports.com
« Reply #3 on: April 11, 2006, 03:41:24 PM »
Mine are plated with standard airbags.  I wouldnt say the ride is harse.  Maybe a little harder than the airbeam ride but not the night and day difference some people make it out to be.  On the interstate I doubt I'd even notice a difference.  If I ever replace the airbags, I'll replace them with rolling lobe, but I won't do it just to get a better ride.
Offline LUKE at US COACH
« Reply #4 on: April 11, 2006, 05:10:10 PM »
Hi Larry & Folks:
If your air beam can be repaired, then I would suggest that you try it.
With regard to the newer air bellows to compensate for bad air beams, the experience in our shop is as follows:
We operated MCI 8's & 9's with bypass plates and the original bellows in commercial charter service.  Never a complaint from customers or our coach operators!!!
Now we have, over the years had several commercial operators come into our shop with MCI's, that had been converted to the newer bellows and asked us to Remove Them,and Add the Bypass Plates and go bag to the ariginal bellows!!!
Each customer responded that passsenger and driver discomfort went to Zero.
The key, when adding bypass plates, is that the ride height of the coach is properly set!!!  With any air ride coach, improper ride height as described in your maintenance manual, will produce an uncomfortable ride along with adding additional stress to the air suspension system along with the coach structure!!!
I Hope this HELPS!!!
Happy & SAFE! Bussin' to ALL.
LUKE at US COACH
Offline edroelle
  • 1998 Royale Prevost
« Reply #5 on: April 11, 2006, 05:56:18 PM »
Now, what I am going to say is very dangerous in that I tend to disagree with Luke - who I consider an expert.
A fellow bus nut (I think he went by Luke Skywalker) had a professional welder repair his front air beams.  He continued to have air leakage such that he plated his air beams and installed rolling lobe bags.  The beams were so perforated with tiny holes, he could not get them closed-up.
I guess the key statement from Luke B.  is, "If your air beam can be repaired."
I thought the ride was somewhat harsh with my MCI 8, plated air beams, and standard air bags.
Ed Roelle
Flint, MI
Offline Melbo
  • MC8 under construction
« Reply #6 on: April 11, 2006, 05:59:09 PM »
I just find it entertaining that LUKE is a newbie.
Melbo
Dallas
« Reply #7 on: April 11, 2006, 06:44:06 PM »
Melbo
I prefer to think of all of us as "FNG's........                                                    Fairly New Guys. LOL
[/b]
Dallas
Offline DC_Bus_Nut
« Reply #8 on: April 11, 2006, 09:56:21 PM »
Let me guess Dallas, you were in the military...FNG.
Offline DC_Bus_Nut
« Reply #9 on: April 11, 2006, 09:59:04 PM »
Additionally, MCI is (was as of 2 weeks ago) having a sale on Airbags. I numerous bags with all of the hardware for $74.oo+ each. A bargain. Installed at DC Trails Bus Repair & Towing here in Wash, DC for a reasonable price too.
Burgermeister
« Reply #10 on: April 11, 2006, 10:48:08 PM »
This is the reprise of a Post by Marc Bourget on Sat Jul 4 10:43:22 1998:
In Reply to: PD4104 airbeams replaceable? posted by Bill on Fri Jul 3
01:04:16 1998:
Gentlemen
The plenums are intended to reduce the "ramp up" or rate of rise in the bag pressure when responding to bump deflections.
The following is a quick attempt at calc'ing some numbers, ( please check my math, but the approach is valid)
Assuming the air bag is a cylinder 6" wide x 10" tall, each inch of air bag height occupies about 280 cubic inches volume. Hitting a bump which moves the axle up two inches would reduce the volume 20% or 56 cu.in. (if the bag didn't expand width-wise by stretching).
If a plenum is 8x8x30" (approximately, as just an example) the total system volume would be about 2200 cu.in. and a 2" displacement (the same 56 cu in) would be only 2.5% reduction in volume.
Back in high school chemistry, Boyle's Law taught us that Pressure and Volume are (inversely) proportional, (assuming Temperature remains the same) In the single bag situation (no plenum) in response to a 2" deflection, an initial pressure of 80 psi would raise to about 100 psi. In the plenum system the same bump would cause the pressure to rise to about 82 psi at the biggest deflection.
This may or may not be a problem. It will make the ride a bit harsher, but whether this is material depends on how youthful the lower back and posterior are as well as the quality of the roads travelled.
More significantly, what will 10 times greater pressure increase (20 psi vs. 2 psi) do to the useful life of the airbags? Personally, I don't know, but as much trouble as they went to to build in the plenum system, and considering the historically tight sphincters of the pencil pushers who control the $$ it is doubtful that the mfg's would have put the plenums in if they didn't have a good reason.
Again, the ol' adage rears its ugly head, you makes your choice and pays your price!
Marc.
Added on Date: 1/17/99
« Reply #11 on: April 12, 2006, 07:41:03 AM »
Hi Melbo & Folks:
That is "OLD"!!!! Newbie.
LUKE
Offline Busted Knuckle
« Reply #12 on: April 12, 2006, 08:07:27 AM »
Melbo
[/b]
Dallas
Dallas fairly is not what it stood for last time I had someone screaming it at me! LOL and I never get lost either 'cause someone's always tell'n me where to go! LOL  ;DKnuckle ;D
Dallas
« Reply #13 on: April 12, 2006, 08:24:23 AM »
Melbo
[/b]
Dallas
Yeah, but I have to be nice 'cause it's a family board, and I use too many bad words as it is.
Besides, It's true, I believe ya'll are fairly nice guys, except when you don't agree with me, then you are obviously the reason this country is going to, unhh, unhh, Damn, I can't say that word!
To a bunch of GREAT GUYS:
Salut!
Dallas
Offline rwc
  • No longer will be Now AM
« Reply #14 on: April 16, 2006, 08:43:12 AM »
I have never heard anyone talk about it but is it possible to get replacement airbeams?? Are the only options to repair the old one or plate and go with just the bellows?  :o
