Author Topic: Plumbing  (Read 5256 times)
Offline Rob
Plumbing
« on: July 25, 2006, 08:47:30 PM »
We are plumbing our bus and need some experties on what size QEST to use? We have a dual pump system and lots of 3/8 QEST! The question is will 3/8 in. be large enough or should we go with 1/2?
        Rob ???
  • Global Moderator
  • Nick & Michelle Badame
Re: Plumbing
« Reply #1 on: July 25, 2006, 10:07:48 PM »
Rob,
Welcome.
I used 1/2" pex and I really wished I used 3/4" from the tanks to the Dist. manifolds. Then 1/2" to the Fixtures.
I wouldn't reccomend 3/8" but, it's your bus you do what your requirements are.
Hope this helps
Nick Badame
Offline Rob
Re: Plumbing
« Reply #2 on: July 25, 2006, 10:49:55 PM »
Thanks!! I was thinking the same thing, I just have 200 feet of 3/8 just  laying around. Hate to see it go to waste but I'll change gears and press on.
        Rob
Offline JackConrad
  • Orange Blossom Special II
Re: Plumbing
« Reply #3 on: July 26, 2006, 04:16:17 AM »
     We used CPVC pipe for our plumbing because we had it on hand. We run 2 water pumps, connected in parallel. We ran 3/4" for the main supply lines (hot and cold) and ran 1/2" lines to the individual fixtures (bathroom sink, shower, kitchen sink).  i would not want anything smaller than 1/2"  Hope this helps, Jack
Offline rip
Re: Plumbing
« Reply #4 on: July 26, 2006, 05:44:07 AM »
When I was doing my plumbing I talked with a bus builder in Phoenix and he was using 3/8" soft copper for his lines except for the washer which he used 1/2" copper.I did the same in my conversion and it works great.I have all the water pressure I want and the soft copper was a lot easyer to use then 1/2".    Don Ripley
Offline Hartley
Re: Plumbing
« Reply #5 on: July 26, 2006, 08:24:47 AM »
I used 3/4 PEX for the main feed lines and 1/2" pex for everything else. It flows pretty good
with the shurFlo 5.7 gpm pump that I have installed.
 I can run the kitchen faucet while the shower is going and not suffered any loss of volume or pressure.
I guess the variable speed pump has a few advantages... It works Great...
The 3/8" inch might be fine for an icemaker line or an auxillary faucet back in the engine bay.
Good Luck.....
