BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Shifter cable length for 102a3 with 740 trans.
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Shifter cable length for 102a3 with 740 trans. (Read 7706 times)
hargreaves
1987 MCI 102A3
Sr. Member
on:
December 22, 2009, 05:27:26 PM »
I am in the process of converting from a 5spd. std. to a 740. I have a 36.5 foot shift cable that I ran through where the clutch rod used to be but it looks to be a tad short. Does anyone know the proper length?
Logged
now as of Feb 2012 series 50 B400 . Sunshine Coast British Columbia
Doug1968
Full Member
Re: Shifter cable length for 102a3 with 740 trans.
Reply #1 on:
December 22, 2009, 05:59:02 PM »
Gerry,
Looks like you are moving right along on the tranny swap. I am interested to see how it turns out. Someone here will help you with the cable length. Keep us posted on how this transmission project turns out.
Doug
Logged
1986 MCI 102A3 - 8V92 - 5 speed
Vancouver, Washington
Ednj
Hero Member
Ed & Sue Skiba
Reply #2 on:
December 22, 2009, 06:10:12 PM »
Hmmm will that 5 fit where my 4 is
Logged
MCI-9
Sussex county, Delaware.
See my picture's at=
http://groups.yahoo.com/group/busshellconverters/
Hero Member
6 Setras, 2 MCIs, and 1 Dina. Just buses ;D
Reply #3 on:
December 22, 2009, 06:12:21 PM »
Gerry,
I wish I could help you with a more informative answer, But I have to tell you truthfully all of ours are shifted by wire & a key pad!
And really not trying to be a smart @$#, but it only needs to be long enough to go from the transmission to beside the driver, not bumper to bumper! FWIW
BK
Logged
Keep SMILING it makes people wonder what yer up to!
(at least thats what momma always told me!
Tom Y
Hero Member
80 5C With Cummins L10 in Progress
Reply #4 on:
December 22, 2009, 06:26:56 PM »
When I went to an auto I mounted my shifter on the vertical surface of the dash. I then measured to the tranny. You need to know if the shifter is pulling or pushing. You may need a loop at the tranny to get the right action. Tom Y
Logged
Tom Yaegle
hargreaves
1987 MCI 102A3
Sr. Member
Reply #5 on:
December 22, 2009, 07:19:24 PM »
B K ya that would be nice but I'm sticking with the non electronic style, everyone tells me they are easier to fix on the road and I am inclined to believe them. Don't have the package (engine - trans ) in yet. but measuring approximately it looks short.
Tom it pushes and pulls lol . I intend to mount it close to where they are mounted stock. The stock shifter will work both ways.
Doug, are you still interested in the tranny?
Logged
JackConrad
Orange Blossom Special II
Hero Member
73' MC-8 8V71/HT740 Southwest Florida
Reply #6 on:
December 23, 2009, 05:27:24 AM »
Where you install the driver's shift control lever will make a difference in the length of cable needed. Our shift tower is on the floor on the right side of the drivers seat. I had thought about moving it to the dash, but by the time I ran the cable forward under the floor, and up behind the dash, it was going to take about 6-8 feet more cable. I decided having the shift tower next to seat was a perfict location for it. Jack
Logged
Tom Y
Hero Member
Reply #7 on:
December 23, 2009, 05:37:53 AM »
I should have worded my post differently. The shifter probally has R on top and 1 on the bottom. I can not remember the shift on the 740. I think the cable went straight in with out a loop, but I will go look. So from R to 1 the cable is pushing at the trans. Tom Y
Logged
Tom Yaegle
Hero Member
Reply #8 on:
December 23, 2009, 05:47:03 AM »
I have driven many buses with different shifter locations, and I personally like the shifter to be down to the right mounted on the floor. The problem with the shifter mounted on the dash is that you have to reach for it to shift. And you are going to be using the shifter more then you might expect. Even though the shifter is not within ready view when mounted on the floor, you can look down to see where it is positioned while driving. But, after awhile you get to know what gear it is in just by the feel of the the shifter knob. Then you'll have a straight shot with the cable, and probably will be the correct length. Good Luck, TomC
Logged
Hero Member
Reply #9 on:
December 23, 2009, 06:17:20 AM »
Just do away with the shifter and cable install a Stone/Bennett shifter you will love it plenty of used ones out there cheaper than the new cable.YMMD
Logged
Tom Y
Hero Member
Reply #10 on:
December 23, 2009, 09:35:28 AM »
I looked at mine and it comes down to the trans, I was thinking it came from the front or back. Sorry for bum info. I bought a new cable I think about 70.00? Tom Y
Logged
Tom Yaegle
Jerry32
Hero Member
Reply #11 on:
December 23, 2009, 04:31:25 PM »
Yea mine is standard 102 with the shift lever on the right of the driver whichis very hady since you use more than you would guess. The standard arangment is R is back and forward gears are forward. Jerry
Logged
1988 MCI 102A3 8V92TA 740
hargreaves
1987 MCI 102A3
Sr. Member
Reply #12 on:
December 23, 2009, 05:05:42 PM »
I plan on putting mine on the floor beside the drivers seat on the right side. There is a fiberglass panel there that the maxi brake valve is mounted to . I am guessing it has to be removed and a new one made to accept the shift tower. My shifter is the R all the way back .
Tom is yours mounted directly to the floor? And is that the floor that is a step above the floor with the brake and gas pedal?
Luvrbus, What is the Stone/Bennett shifter?
Logged
Just Dallas
Bus Conversion Stuff on a Budget
Hero Member
Reply #13 on:
December 23, 2009, 05:11:21 PM »
Removed
Logged
JackConrad
Hero Member
Reply #14 on:
December 24, 2009, 03:28:47 AM »
Quote from: hargreaves on December 23, 2009, 05:05:42 PM
Stone-Bennett shifter is an electrically controlled air soperated shift mechanism. All that is up front in the drivers area is a toggle switch or a touch pad to select the gear you want. Advantages: no cable to run from front to back, no shift tower (less "cluttered" drivers area) Disadvantages: requires air pressure before you can shift (don't shut bus off in gear or have a method to disable neutral start switch). More components (more possible failure points). Jack
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
