BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
air leaks and kits MC8
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: air leaks and kits MC8 (Read 9292 times)
rcbeam
Full Member
on:
August 30, 2011, 02:26:29 PM »
Decided it was time to investigate some air leaks today, so got out the soap squirt bottle and crawled into the spare tire compartment. Found a couple of fittings that just needed tweaking but the big item was a square silver thing that had the marking of QR1 on it. My pressure regulator for the blower belt tensioner has been leaking out the weep hole for a while, but when I sprayed it down, I had a whole nest of bubble all over it. So it was leaking much worse than I thought. Also found the air control for the missing shutters leaking lots of places so I am just going to remove and cap the air line for that. Called our good busnut friend Luke and he said the silver thing was a quick release valve (guess the QR1 was a big hint for him). He is sending me rebuild kits for both the pressure regulator and the quick release valve.
I also looked at the tires on the rear. I could not find the DOT date on the drives but I found it on one tag... was 3301. Had no idea the tire was this old. The drives look really good and I cannot find any cracks any place but can't find the date either. Not sure if they put it one both sides or not. I've not really had the bus on the road much since I've had it, but guess it's a good thing. I put new steers on last fall but looks like I need 6 tires for the rear now. Guess that will take care of the best part of 3 grand. My two fronts installed were just change under $1k for the pair.
Logged
Russell
1976 MC8
Lexington KY
www.sweeteveningbreeze.blogspot.com
thomasinnv
Derrick Thomas
Hero Member
I may be nuts, but only for buses
Re: air leaks and kits MC8
Reply #1 on:
August 30, 2011, 04:35:22 PM »
I believe the dot codes are only on one side of the tire.
Logged
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Hero Member
1980 MCI MC-5C
Reply #2 on:
August 30, 2011, 07:08:59 PM »
Both the quick release valve and the pressure regulator are easy rebuilds, you do need to reset the pressure regulator to 21 PSI for the blower fan belt. One thing - the exact same pressure regulator is used for the emergency/parking brake system. Mine failed on me, so now I carry a spare unit set to 85 PSI so I can swap it if I need to.
Logged
rcbeam
Full Member
Reply #3 on:
September 03, 2011, 01:53:54 PM »
Received the kits from Luke Friday and proceeded to rebuild the parking brake QR1 first.
PROBLEM 1
: Only two parts in the kit, diaphragm and grommet (o-ring). When I read the OPERATION portion in the manual page 4-19, it says in part "...the diaphragm spring forces the outer edges of the diaphragm against the body seat." in paragraph 2. I could not find a 'diaphragm spring' in my QR1. When I reassembled and installed the valve, aired up the bus I STILL have air leaking out of the exhaust port when the parking brake is SET, but not when released. Same condition I had before I rebuilt the valve. The diaphragm was hard in the center and so it still needed to be rebuilt, but now I have no clue why it still leaks. Could I have a leaking parking brake chamber feeding back through or something wrong some place else causing the leaking out the exhaust port or am I missing a diaphragm spring?
PROBLEM 2:
I also rebuilt the pressure regulator for the blower belt tensioner. It leaked out the weep hole in the back of the regulator and when I sprayed it with soap bubbles, it blew bubbles from everywhere really bad. After the rebuild I have just a few very small bubbles around a couple of screws and I snugged them down good but I have LOTS of air out the weep hole... so much that I could hear it leaking all the way from the front of the bus. It is leaking much worse out the weep hole now than it did before I rebuilt it. So I shut it all down, closed up shop and came home. On the drive home I thought about the fact that I had not yet adjusted the air pressure to 21 lbs... I did install the adjusting screw the same number of turns as before, but have not checked the pressure. I was told by a bus mechanic friend of mine that the leaking out of the weep hole is due to a leaking air cylinder but when I asked Luke about it when I ordered my kits, he said he had never heard of that.
So any ideas on what I should check or do next to address the two leaking rebuilt valves?
Logged
Russell
1976 MC8
Lexington KY
Rick 74 MC-8
Sr. Member
Reply #4 on:
September 03, 2011, 02:35:59 PM »
I had the same leak off my alternator tensioner. I pulled the cylinder apart went to the hardware store got new orings all is good. cylinders are spring loaded I held it in the drill press took the end off and release the tension. if I remember correctly it only had about two inches of preload
Rick
Logged
rcbeam
Full Member
Reply #5 on:
September 03, 2011, 06:08:39 PM »
Thx Rick...looks like my friend was right and I need to put new o-rings in the air cylinder.
Back to the parking brake QR1, I have been studying the book and looking at air diagrams. Looks like the QR1 output goes to the inversion valve. I have read the section on the inversion valve operation, but can't quite get my brain wrapped around it all. So I still don't know if I need to rebuild the inversion valve, or if I have a problem in on of the rear brake cans, leaking back through the inversion valve to the QR1.
Anybody care to offer an input?
Logged
Russell
1976 MC8
Lexington KY
Rick 74 MC-8
Sr. Member
Reply #6 on:
September 03, 2011, 07:19:56 PM »
I would think you could take the airline off the brake can and plug it see what happens. That's probly where I would start
Rick 74 MC-8
Logged
Hero Member
Reply #7 on:
September 04, 2011, 12:12:01 AM »
post your unit number so I can use the correct schematic to spin you some more!
Logged
rcbeam
Full Member
Reply #8 on:
September 04, 2011, 08:30:33 AM »
buswarrior: DOM: MAY 1976; SERIAL NO: 1507; UNIT NO: T46-442. I have a TMC COACH. My book is MCI and the last time I called MCI to order some parts I asked them about TMC books or converting my serial number to a MCI number to reference the schematics in the MCI book.... he had no clue.
Hope this helps you find something... thx for looking for me.
Logged
Russell
1976 MC8
Lexington KY
rcbeam
Full Member
Reply #9 on:
September 04, 2011, 09:41:08 AM »
I just got back in from trying to adjust the pressure on the blower belt tensioner pressure regulator. When I hooked up my guage, it ready 35 psi, so I backed out the bolt on the back... the lowest it would go is 26 psi with the bolt almost ready to fall out. When I screwed it in, the pressure went up but the leaking out the weep hole slowed down. At any rate, it won't adjust down further than 26 psi.
It looks like to me the regulator is backwards. The control valve is plumbed to the outlet side of the regulator with the inlet side going to the test port and the rear most hose on the air cylinder. Maybe I just don't understand it.
I'm lost.
Logged
Russell
1976 MC8
Lexington KY
Hero Member
Reply #10 on:
September 04, 2011, 11:46:34 PM »
The pneumatic belt tensioner is powered in both directions.
It will provide belt tension one way, and will retract the tensioner in order to make belt changes a snap.
If it is working correctly...
I'll get the manuals out for the rest if I can squeeze in a little time. Awful busy with work, too tired for schematic chasing and typing stuff accurately that needs thinking!
Logged
Hero Member
1980 MCI MC-5C
Reply #11 on:
September 05, 2011, 09:30:42 AM »
I just redid mine this morning, because when I re-installed mine I after changing the engine I couldn't get it to work right, symptoms exactly the same as yours. Air dumping out of the exhaust hole on the pressure limiting valve, the control valve wasn't working right. I took it all apart and installed a new pressure limiter, and plumbed it so that air comes into the control valve, into the input side of the pressure limiting valve, and out to the rear port of the cylinder. I set the limiter to 21 PSI. As it came out of the bag it was set to zero, and I cranked it in a few turns to get it up to 21 PSI, so they definitely should be able to got that low.
Now it works fine, the air cylinder is leaking a bit as is the control valve, so I will take them apart and have a good look.
Edit: took apart the control valve and replaced the O-rings. It's held together by a snap ring on the bottom, fiddle that off and it comes apart. Now the last problem seems to be that the cylinder is leaking air from the rear section to the front section, it travels out of the hose and back to the control valve and out the exhaust port at the top, and it probably shouldn't do that. I will take it apart later.
Logged
rcbeam
Full Member
Reply #12 on:
September 06, 2011, 07:04:18 AM »
So Brian, according to your plumbing description, my pressure regulator is indeed installed backwards and has been all along. Probably why I can't get it to adjust down correctly.
Logged
Russell
1976 MC8
Lexington KY
Hero Member
1980 MCI MC-5C
Reply #13 on:
September 06, 2011, 07:32:36 AM »
Well maybe it was a funky option because mine was installed exactly the same as yours, so who knows. My pressure regulator is now brand new, from Luke, but it adjusted down to zero. I adjust mine off the bus, in my shop, I just screw in a gauge on the outlet side and an air line fitting on the inlet side. I did find a picture of it in my manual that shows that it is supposed to be installed with the air going into the inlet on the pressure regulator and out the outlet (it seems so silly to write that, but there you go).
I am at the point where I need to rebuild the air cylinder and then it should be good. I am leaking from the push side of the air-cylinder out the retract side port, so that is the last thing I need to fix. I put new o-rings in the control valve, but it wasn't the problem.
Logged
rcbeam
Full Member
Reply #14 on:
September 08, 2011, 02:04:34 PM »
I asked Luke about my pressure regulator and QR1 valve issues and he was supposed to call me back. Haven't heard from him yet. As for the book mentioning diaphragm seat and spring, I poked around on the internet and found a site that showed the evidently older QRV valve as having the seat and spring, while the newer QR1 does not have a seat and spring. So mine is not supposed to have one. There u go. As for leaking out the exhaust port it still does. Tomorrow I am going to take it out and apart again and turn the new diaphragm over and reassemble it and see what it does. I am also going to study the book more and see if I can figure out what would probably be leaking out the exhaust port. Someone mentioned the brake cans leaking, but when I looked at the book the inversion valve is the first thing inline from the QR1 so I don't know if it could be bad or not either.
As for the pressure regulator on the blower belt tensioner, mine was installed backwards originally... not sure how dumb you need to be to do that, but it was. So today i removed it, took it apart just to check things inside again, put it back together and installed it with the control valve to the IN and the OUT to the air cylinder. Now it works like it should, I was able to adjust to 21 PSI (it had a metal tag on the adjustment stating the pressure required) and best of all it now does not leak out the weep hole or any place else.
So one down and one still to go. Maybe if I study the book part on brakes enough I'll figure something out on the QR1 leak.
Logged
Russell
1976 MC8
Lexington KY
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
