BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
help with air brake problem
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: help with air brake problem (Read 8276 times)
thomasinnv
Derrick Thomas
Hero Member
I may be nuts, but only for buses
on:
September 24, 2011, 10:08:40 PM »
A friend of mine has a motor home that is around 5 or so years old, a 39' fleetwood on a freightliner chasis, air suspension and air brakes. It has set for a couple years un moved and when he tried to move it today he has an air problem. The air builds to 120 just fine, but when you press on the brake pedal the front and rear air gauge drops like a rock. same thing if you try to release the parking brakes, drops like a rock and you hear a massive amount of air under the rig. was fine when it was driven in and parked there a year or two ago. is there some type of main valve under there somewhere that is causing this? what say the experts?
Logged
1998 MCI 102-DL3
Series 60 12.7/Alison B500
wal1809
Hero Member
Re: help with air brake problem
Reply #1 on:
September 25, 2011, 03:18:15 AM »
First question is where is the air coming from specifically when you hear it?
Logged
www.snakebreaker.com
prevosman
Full Member
Reply #2 on:
September 25, 2011, 04:07:58 AM »
Sure sounds like bad diaphragms in the brake chambers.
Logged
Jon Wehrenberg
Knoxville TN
1997 Prevost Liberty
Joe Camper
Hero Member
Reply #3 on:
September 25, 2011, 05:15:21 AM »
What you have described is 2 different leaks.
WHen you try to release the parking brakes and it leaks that is "Emergency air".
When you depress the brake pedal that is "Service Air" that is leaking.
Tough to diagnose from here it would be pure guess. You need to get under there and identify where its coming from.
Logged
zubzub
Hero Member
'53 4104. Roadworthy but rough around the edges.
Reply #4 on:
September 25, 2011, 06:20:11 AM »
WAG is the air relays are wonky....if you are lucky tapping on them etc might help...also a little oil if you crack a line. Seems to me the relays could easily get a little corrosion/sticky sitting for a couple of years, and the relays are probably similar for the emerge brake and service...actually could be just one combined anti compounding valve... which would explain the identical symptoms....WAG.
Logged
more pics of bus stuff
http://s392.photobucket.com/albums/pp3/zubzub_photos/prevost%20scrap%20and%204104%20interior/
Hero Member
Reply #5 on:
September 25, 2011, 06:25:09 AM »
It has a dual air system and mice love the the plastic lines and those have a lot of the push in type fitting with plastic lines
Logged
thomasinnv
Derrick Thomas
Hero Member
Reply #6 on:
September 25, 2011, 07:04:57 AM »
not sure I will have time today, but sometime in the next day or two I will go over to his place and crawl under there and see where the air is coming out of.
Logged
1998 MCI 102-DL3
Hero Member
Reply #7 on:
September 25, 2011, 07:21:44 AM »
Just as with a bus be sure to block it up while under there. A motorhome can kill you just as dead as a bus. I've seen motorhomes that get pretty low with the air dumped.
Logged
oldmansax
Hero Member
Reply #8 on:
September 25, 2011, 04:23:54 PM »
This info may be dated, but then again, so am I!
When trucks started using spring parking brakes as opposed to air parking brakes (which would eventually leak off & release the brakes), they started having massive brake component failures. Come to find out if the service brakes were applied while the parking brakes were applied, the combination on the two would put way more force on the brake assembly than it was designed to handle & it something would fail. Soon all systems were equipped with a protection valve which would not allow air pressure to be applied to the service brakes if the parking brakes were applied. If the diaphragm(s) in that valve fail, all air pressure will exit if you try to disengage the parking brakes OR if you try to apply the service brakes.
I seem to remember the valve in question has 5 or 6 connections and is usually located in such a way that the entire vehicle has to be disassembled to replace it....... DAMHIK!
This valve may have been replaced with some electronic device in newer trucks, I don't know.
TOM
Logged
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
Len Silva
Hero Member
Angle Parked in a Parallel Universe
Reply #9 on:
September 25, 2011, 05:27:27 PM »
An anti-compounding valve is just a relay valve with a double check valve as part of the assembly. Not all that complicated.
http://www.zafr.com/trucktcom/brakes_compounding.htm
http://www.anythingtruck.com/Merchant2/merchant.mv?Category_Code=HTP-AIRB&Product_Code=060-289714N&Screen=PROD
Logged
zubzub
Hero Member
Reply #10 on:
September 25, 2011, 06:29:07 PM »
It is because both the service and the parking brake drain air fast when applied, that I suspect the anti compounding relay/valve. Also it is a good way to lose air fast, as opposed to a small leak in a diaphram.
Logged
Hero Member
Reply #11 on:
September 25, 2011, 06:56:05 PM »
The anti compound feature on a R-14-R-16 works after the spring brakes are released could be the QR feature but I think he he has bad lines on the front and a rear with that being a dual air system.
Derrick will get her done he has a set of Jakes and blower seals here he need to install while I watch LOL
Logged
thomasinnv
Derrick Thomas
Hero Member
Reply #12 on:
September 25, 2011, 09:40:55 PM »
I'm gonna try to get a look at her tomorrow. I will be setting up the gospel tent in the AM, but might have some time tomorrow afternoon to get a gander under neath. Good thing about the freightliner chassis is that even with all the air dumped I can still almost sit up underneath it. lots of room to crawl around.
Clifford, when I get there to do the jakes and seals I need your set of eyeballs. I am still fighting a major oil leakage problem. I have already replaced just about every oil seal, hose and gasket short of ripping off the heads. I have catch cans so it's not the air box drains, we will talk in a few weeks.
Logged
1998 MCI 102-DL3
AndyG
Jr. Member
Reply #13 on:
September 26, 2011, 07:05:12 AM »
Don't forget to chock the wheels just in case the brakes decide to release while you are under the coach.
Logged
thomasinnv
Derrick Thomas
Hero Member
Reply #14 on:
September 26, 2011, 02:54:15 PM »
got under there today and took a gander. Seems that something has chewed through the big air brake lines that attach to the valve just in front of the rear axle.
Logged
1998 MCI 102-DL3
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
