BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Bus heater core removed how to bypass
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Bus heater core removed how to bypass (Read 9931 times)
Scott & Heather's buses: MCI-9 & MCI-102
Hero Member
MCI-9 & MCI-102
on:
May 12, 2016, 01:48:28 PM »
My bus heater core (main one) is removed but drivers heat is still hooked up. Can I just run a radiator hose from one heater core pipe to the other in the condenser bay? Or should I block each one off with a copper cap soldered on? What's best practice?
Logged
gumpy
Some Assembly Required
Hero Member
Slightly modified 1982 MC9
Re: Bus heater core removed how to bypass
Reply #1 on:
May 12, 2016, 04:14:49 PM »
I would cap them. The driver's heat comes from the same lines. If you have too little restriction (i.e. tied together) you might no get enough flow through the driver system.
Logged
http://bus.gumpydog.com
- "Some Assembly Required"
Hero Member
MCI-9 & MCI-102
Reply #2 on:
May 12, 2016, 04:23:11 PM »
I did notice in my research is that the lines were teed off from the main heater core lines so before I actually open the gate valves to allow the drivers seat to work I wanted to make sure I don't with the heater core lines open so I will cap Them thank you so much
Logged
jav9956
Full Member
MCI 102A3 DD6V92 Los Angeles, California
Reply #3 on:
May 12, 2016, 04:24:06 PM »
I capped them. What I figured was the best way to keep flow going just as intended.
Logged
Bjorn and Lauren
Back to School Bus
www.backtoschoolbus.com
Geoff
Hero Member
Reply #4 on:
May 12, 2016, 05:33:45 PM »
What is the difference between shutting off the heater lines off and capping them? Nothing. Since I have the finest bus made, a GMC RTS, I took the heater and air conditioning air handler out, saved the heater core, and use the heating system radiator (heater core) and made it into an auxiliary cooling radiator for the engine. I kept the driver's heat and plumbed it into a Webasto heater to 1) pre-heat the engine, and 2) use as an interior heater (very nice).
--Geoff
Logged
Geoff
'82 RTS AZ
Hero Member
Reply #5 on:
May 12, 2016, 06:00:53 PM »
do Webasto's come with noise canceling headphones...
Logged
jav9956
Full Member
Reply #6 on:
May 12, 2016, 06:04:11 PM »
Quote from: Geoff on May 12, 2016, 05:33:45 PM
If you simply shut them off you cannot use the drivers heat, which I believe was the main goal that Scott is trying to achieve.
Logged
Bjorn and Lauren
Back to School Bus
Hero Member
MCI-9 & MCI-102
Reply #7 on:
May 12, 2016, 06:16:23 PM »
^bingo
Logged
Hero Member
Reply #8 on:
May 13, 2016, 02:02:24 AM »
Capping is correct.
A bypass loop would introduce an opportunity to overheat the engine, as there will be no way to cool that hot coolant before it returned to the engine.
Logged
Hero Member
MCI-9 & MCI-102
Reply #9 on:
May 13, 2016, 07:08:51 AM »
Ok. Thanks. So now after three plumbing stops, I haven't found caps the right size to do this? What's your secret Bjorn?
Logged
jav9956
Full Member
Reply #10 on:
May 13, 2016, 07:58:11 AM »
This was about 6 months ago already (scary to realize). You may already know this so forgive me if I am not telling you anything new. When measuring a pipe the measure is from the inside diameter... so a 1 1/4" pipe is the inside diameter and the outside is likely 1.625" or something thereabouts. The easiest thing to do, I think, is to make sure to measure the inside and outside diameter, then extrapolate the wall thickness and make a note of that. I like numbers so I take all the numbers and my measuring tape to the hardware store and measure out what I need and that generally works well. Sometimes I just look for a pipe with the exact measurements of mine so I have a "replica" in my hand at the store. From there I just see what fits on it
I think is was a 1 3/4" copper cap that I ended up using but I just don't remember, it did fit snug.
Anyhow, I think a lot of people get confused between measuring tube (size measured from OD) and measuring pipe (size measured from ID) because we huMANs like to make things confusing!
I hope that helps.
Logged
Bjorn and Lauren
Back to School Bus
gumpy
Hero Member
Reply #11 on:
May 13, 2016, 09:08:45 AM »
Should be 1 1/2".
Maybe you've seen this, but here's a page I did on repairing one of the valves on mine. Maybe there's something in there to help you...
http://www.gumpydog.com/Bus/MC9_WIP/HVAC/Coach_HVAC/Coach_Heating/Repairing_Coach_Heat_Gate_Valve/repairing_coach_heat_gate_valve.htm
Logged
Hero Member
Reply #12 on:
May 13, 2016, 10:13:37 AM »
Find a company that does commercial installation of piped air compressor piping. When placed in concrete the tubing is proprietary, similar to commercial refrigeration copper.
One or the other should have what you need. you have "hard" copper.
Logged
Hero Member
MCI-9 & MCI-102
Reply #13 on:
May 13, 2016, 11:59:32 AM »
Thank you bunches. Today I reconnected the drivers heat so all I need to do is cap the lines in the bay, add coolant and I should have heat
Bjorn, you were super helpful, thanks again....ill check
Out Craig's link....
Logged
jav9956
Full Member
Reply #14 on:
May 13, 2016, 03:22:12 PM »
If your evaporator is good a guy was contacting me trying to buy one, also needs a compressor.
Don't know what you plan on doing with your evaporator but if you are interested in selling you might be able to make a couple bucks to put into the conversion
. Let me know and I can give you his contact info.
Logged
Bjorn and Lauren
Back to School Bus
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
