BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
tire size
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: tire size (Read 3874 times)
dj
Jr. Member
tire size
on:
February 28, 2018, 06:26:25 PM »
Hey Guys just curious on what size tire your running...I have 11R24.5 and Im thinking going to 22.5 short rubber any thoughts?
Thanks Doug
Logged
Hero Member
Re: tire size
Reply #1 on:
February 28, 2018, 06:40:39 PM »
Revolutions per mile and load carrying capacity
Those are your two decisions.
Revolutions has a subtle effect on gearing, load carrying is a safety decision.
Buses used to be aimed at 495 revolutions per mile stock. The GM folks would seek out the tallest/lower rpm tireto squeak an extra couple mph outoftheir gear limited drivetrain. A heavy conversion might choose a higher number to squeak betterhill or headwind performance.
These are all subtleties, it won't change the world...
Happy coaching!
Buswarrior
Logged
DoubleEagle
Hero Member
BCM Subscriber
Re: tire size
Reply #2 on:
February 28, 2018, 07:40:03 PM »
11R24.5 tires will cost a little more to replace, but if you want to run Alcoa's, the cost of switching to 22.5 rims will negate that. 22.5 rims are more common now, but it used to be the other way around. If excise taxes or some other factor changes the economics, things might change again. I think the bigger rims look better.
Logged
Walter
Dayton, Ohio
Hero Member
Re: tire size
Reply #3 on:
February 28, 2018, 07:44:44 PM »
What size does the chart say on the bus,Eagles were the only bus that ever ran 24.5 tires that I know of
Logged
Hero Member
Re: tire size
Reply #4 on:
February 28, 2018, 08:19:29 PM »
the guys (engineers) who designed the bus chose what's on it for good reasons.
Logged
Hero Member
Re: tire size
Reply #5 on:
March 01, 2018, 07:59:22 AM »
I wouldn't change tire sizes. Both my bus and truck have 11R-24.5 rubber. As long as you can get 11R-24.5's, why change? You'll loose some top end speed.
11R-24.5 are 476rpm (revs per mile). 12R-22.5 are 485rpm. 11R-22.5 are 500rpm. 275/80R-22.4 or 295/75R-22.5 (most popular tire sizes now on big rigs) are 517rpm. Just multiply your rear end ratio by tire rpm to find out what engine speed you'll get at 60mph. Good Luck, TomC
Logged
dj
Jr. Member
Re: tire size
Reply #6 on:
March 01, 2018, 05:12:08 PM »
Thanks for the information guys ....the data placard says 22.5 so Im thinking about going to the smaller rubber so if I take it up to the mountains for skiing ill at least have room to throw tire chains on if i need to
thanks again for the info Doug
Logged
Scott & Heather's buses: MCI-9 & MCI-102
Hero Member
MCI-9 & MCI-102
Re: tire size
Reply #7 on:
March 02, 2018, 04:12:40 AM »
So you’re willing to replace all your rims? I love my 24.5’s:
Logged
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
tire size
