Author Topic: 4104 671 fan hub  (Read 1463 times)
Offline Nel
4104 671 fan hub
« on: March 24, 2019, 08:47:45 AM »
Getting the bus ready for new season, I always inspect the famous fan hub that eventually fails and launches the fan. I was just wondering if anyone has tried to drill and run a bolt thru the shaft diameter between the hub on the engine and the fan mount. I know its the rubber between the inner and outer shafts that fail, would a bolt work to keep them from seperating?
4104-4519
West Nyack , NY
Offline Boomer
Re: 4104 671 fan hub
« Reply #1 on: March 24, 2019, 06:48:19 PM »
This is how I protected my radiator on the Silverside.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
Vancouver, WA USA
Offline gg04
  • Full throttle 'til you see God
« Reply #2 on: March 25, 2019, 06:31:59 PM »
I've seen both drilled and screwed and straped..
If you personally have not done it  , or saw it done.. do not say it cannot be done...1960 4104 6L71ta ddec Falfurrias Tx
