BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
How do YOU handle propane restrictions?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How do YOU handle propane restrictions? (Read 2600 times)
Jim Blackwood
Call me Doc, or call me arsehole, just don't call me late to dinner.
Hero Member
I'm 25% Farnsworth ;-)> 1996-MCI 102DL3
on:
March 28, 2019, 12:18:35 PM »
Tunnels are often "No Propane" areas. I'd like to just open this for discussion and see where it goes.
Logged
Geoff
Hero Member
Re: How do YOU handle propane restrictions?
Reply #1 on:
March 28, 2019, 12:23:32 PM »
Probably no where. Did you do a search?
Logged
Geoff
'82 RTS AZ
Dave5Cs
Hero Member
BCM Subscriber
Reply #2 on:
March 28, 2019, 01:46:17 PM »
https://www.aisinsurance.com/products/recreational-vehicle/rv-articles/traveling-with-propane.aspx
Logged
richard5933
Hero Member
Reply #3 on:
March 28, 2019, 02:29:33 PM »
I've only encountered this going through a tunnel near Baltimore. Depending on the state and the size of your propane tank, you may or may not have a problem. The tunnel near Baltimore prohibits tanks larger than 10 gallons (and you can only have 10 of them.) Not likely to be a problem for any of us.
Some states (or individual tunnels) require that tanks be shut off. Others don't. You need to be aware of road restrictions, just like with bridge heights, etc. I believe that there is a feature on some Garmin GPS units that will show propane restrictions.
One of the reasons to maintain OTR heat is so that the propane can be kept off while traveling. We stay toasty and have no need for propane while underway. Our fridge is 12v/120v (no LP) so that's not a problem for us either. Most fridges that run on LP can also run on 12v, so that shouldn't present a big problem for anyone, especially if you're able to charge the house batteries while on the road.
So, we only run the propane while camped, and then only when dry camping. Otherwise we use electric heat & cooking.
Logged
Gary Hatt - Publisher BCM
Publisher - BCM
Administrator
Hero Member
Reply #4 on:
March 28, 2019, 07:18:46 PM »
I bought an all-electric bus. Propane was always a nuisance to deal with. Not only in tunnels on the east coast but just getting the tanks filled.
Logged
Dave5Cs
Hero Member
BCM Subscriber
Reply #5 on:
March 29, 2019, 07:45:36 AM »
And if in a bay leave the bay door marked (LPG contrasting lettering)and unlocked in case the fire department needs to find it fast or just to know where it is in a fire.
Logged
Jim Blackwood
Hero Member
Reply #6 on:
March 29, 2019, 07:49:36 AM »
I'm not real informed about this which is why I started the thread. I've heard of stupifying fines in some cases and naturally want to avoid those. At the same time I wonder if propane fueled vehicles are banned from tunnels? No doubt the devil is in the details, so I figured it'd be a good idea to know those.
Logged
richard5933
Hero Member
Reply #7 on:
March 29, 2019, 08:44:31 AM »
Here's some basic information. Please verify if traveling in these areas since regs change. Some of these are prohibitions. Some are just restrictions.
https://www.rvtripwizard.com/rv-info/propane-tanks-in-tunnels.php
Here's a thread from the FMCA forum talking about the same thing.
https://community.fmca.com/topic/6851-going-through-tunnels-with-a-motorhome/
There are apparently allowances for vehicles fueled by CNG related to OEM equipment, size of tanks, etc. Some of the rules vary, allowing for example a vehicle powered by CNG but not one powered by propane. Since this is not relevant to this conversation I didn't spend too much time reading about it.
Logged
Hero Member
Reply #8 on:
March 29, 2019, 08:48:13 AM »
Source your info from the authorities.
I have never read so much trash as I have on road going legal matters as I have on RV forums...
And "RV" publications aren't far behind in publishing useless, poorly researched fluff.
DOT from each jurisdiction will have tunnel info, or a tunnel authority with its own site.
My preference is also all-electric. Lots easier a choice today, with the advances in solar panels, vs 20 years ago.
But that still leaves the potential for forgetting about a propane outdoor grill and it's fuel supply, rolling around downstairs somewhere...
Go to the SOURCE in all things.
Happy coaching!
Buswarrior
Logged
DoubleEagle
Hero Member
BCM Subscriber
Reply #9 on:
March 29, 2019, 08:54:17 AM »
The main problems are in tunnels and areas in Massachusetts, New York, Virginia, and Maryland. The two tunnels in Baltimore are the most notorious with a maximum individual tank size of 10 pounds. I used to drive buses and trucks into Baltimore, and I can't recommend going through there with or without propane.
Logged
Walter
Dayton, Ohio
Hero Member
Reply #10 on:
March 29, 2019, 09:08:34 AM »
Easy-just don't go where there are tunnels!
Logged
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
