Author Topic: strange turbo sound??  (Read 5658 times)
Re: strange turbo sound??
« Reply #15 on: April 09, 2019, 03:19:43 PM »
David any good muffler shop can expand the pipe or the flange to fit they do it everyday
Offline eagle19952
Offline David Anderson
  • just outside San Antonio TX
« Reply #17 on: April 09, 2019, 04:33:01 PM »
I did some driving around in SA today and nobody said they could expand the flange.  I will have to keep looking some more.
They want to do a butt splice weld.  I'm sure there is a reason Eagle didn't butt splice this fitting when it was built.  I don't feel comfortable with that type of splice.
« Reply #19 on: April 09, 2019, 05:08:31 PM »
The flange Eagle used was a Nelson or a Riker, man where is Norris when you need him I looked through some papers and never did find where I bought those flanges or the complete 90 bend
« Reply #20 on: April 09, 2019, 06:29:17 PM »
This may work.  No length given.  I will have to call tomorrow
« Reply #21 on: April 10, 2019, 01:16:25 PM »
That one won't work.  It is too long on the flare side to the corner and too short on the sleeve side to reach the next exhaust joint.
I need 10" from the flare to the corner and 12" from the corner to the end of the sleeve.
The combo in my following attachments may work.  I can cut the 12" leg and somehow get the flare welded on there.  The other leg with the sleeve is 12" which is perfect.
The flare in the attachment from United Muffler is 5.63" which is exactly what I have now.  Apparently I have a marmon flare to my turbo pipe.  This is the only 5.63" fitting I've found.  All others have been 5.75 or 5.88.
The challenge is getting a 5"OD flare welded to 5"OD elbow pipe.
BTW-the rebuild price on my turbo is $1300
Offline chessie4905
« Reply #22 on: April 11, 2019, 06:44:48 AM »
I don't know why you can't get it butt welded by a competent welder. Scores of piping have been butt welded over the years with no issues. You could also work the end of elbow with a ballpein hammer to enlarge it enough to allow the flange to just enter the pipe a touch. Many exhaust pipes for special applications have pieces butt welded together.
« Reply #23 on: April 11, 2019, 08:01:54 AM »
The factory uses butt welds a blacksmith forge weld type I doubt a regular wire weld would hold in the long run
Offline chessie4905
« Reply #24 on: April 11, 2019, 11:15:36 AM »
Have it stick welded with a good alloy rod by a certified welder.
Offline Jim Eh.
  • Excess in moderation
« Reply #25 on: April 11, 2019, 07:06:17 PM »
I do this for a living. Butt welds properly done will outlast the tubing. ALL Y pipes are basically butt welded. The only way possible. As long as the weld is done by a competent welder it will probably outlast you.
BTW, with the looks of that flare the Vband clamp was probably loose. Make sure you replace it as well.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
« Reply #26 on: April 15, 2019, 04:10:47 PM »
I enlisted a local welder to attach the flange.  $40 later it was ready to install.  It took lots of grinding, filing, and buffing to get it to seat correctly to the cast iron elbow.  Whew, the whole exhaust assembly is a tight fit all the way to the muffler, but I got it done.
I followed the startup procedure instructions precisely, and all went well.  The bus ran great.
Offline daddysgirl
  • Second build on the third bus...Yes, it takes a nut!
  • Daddy's Girl Jr.
« Reply #27 on: April 16, 2019, 10:37:54 AM »
Beautiful turbo!
I don't have one, so I admire others...
Andrea   Richmond, VA
