Author Topic: Dash replacement  (Read 1575 times)
Offline edvanland
Dash replacement
« on: April 23, 2019, 08:36:15 AM »
Looking at replacing the dash on my MCI 7 with a custom instrument one. I have a 8V92 so any ideas on where is the tack hooked up as well as oil and hot engine ( 2 of them) lights. It will have a GPS speedometer as well as oil, temp, air pressure, and fuel so any help or ideas will be appreciated. I am assessing which of the idiot lights of the 21 which are in the rectangle panel on the lower left side to keep.
ED
Ed Van
MCI 7
Cornville, AZ
Offline neoneddy
    • Youtube Build Log
Re: Dash replacement
« Reply #1 on: April 23, 2019, 08:42:06 AM »
for the Tach I'm using the R terminal on the alternator,  I think I tapped it at the relay in the back.   I had to run my own wire for it, not sure if yours came stock or you're adding one.
Raising hell in Elk River, MN
1982 MCI MC9
6V92 / 4 Speed Auto (HT740) Video Build Log - Bus Conversion & RV Solar company we now started thanks to our Bus
Offline bevans6
  • 1980 MCI MC-5C
« Reply #2 on: April 23, 2019, 08:52:39 AM »
Many places to be legal you need a low air light, as well as the buzzer.  You should have a no-gen light, and a volt meter.  Turn signal lights, headlight on and high beam, all I can think of off the top of my head.  I don't have nor miss a tach.
Offline daddysgirl
  • Second build on the third bus...Yes, it takes a nut!
  • Daddy's Girl Jr.
« Reply #3 on: April 23, 2019, 10:48:15 AM »
FWIW...
I would keep the Low Oil, Low Air, Not-Gen, Emergency Brake, and headlights on/high beams.
Andrea   Richmond, VA
Offline edvanland
« Reply #4 on: April 23, 2019, 01:36:17 PM »
Daddysgirl
You pretty much nailed it. I plan on keeping several more just have not decided which ones yet. I will read the book on gauges in the Bus Conversion Magazine and not be in a hurry.
Ed Van
MCI 7
Cornville, AZ
