Author Topic: Macerater tiolets  (Read 4323 times)
Offline Knuckles
Macerater tiolets
« on: April 19, 2020, 07:39:45 AM »
Just wondering how many of the full timers have switched to macerater toilets as i have. Two years ago i got tired of rv style toilet and as mine needed replacing i switched to a 12volt johnson pump marine toilet  at first I couldn't figure out itjust kept pumping water an i put a 12 volt solenoid on the water line and it only turns on water when the flush button is pushed. The discharge hose just goes into blackwater tank when boondocking and when I'm staying for any time longer than a few nights i stick it into gray tank and leave tank open and grey all the grey and black discharge drain constantly out the pipe that way both tanks stay empty and when i decide to go i justclose the valve roll op the hosecand leave. I know they now use them in high end trailers like airstreams But do not know if anybody else has tried them yet. I can't tell you how much i love this toilet anddhave had no troubles at all in two years plus. You can use any kind of toilet paper but have to make sure nobody puts any feminine products in it or it will jam impeller. Would like to know if anybody else has trieddthese toilets and any problems you've had
GM 4107 8V71  V730
Re: Macerater tiolets
« Reply #1 on: April 21, 2020, 08:57:35 AM »
Nothing more reliable than a gravity toilet.
Offline chessie4905
« Reply #2 on: April 21, 2020, 11:43:03 AM »
Macerater toilet, webasto furnace, instant water hearer, heat pumps...they are great items when they work as designed. But then issues crop up out on a camping trip after working flawlessy for a couple years. Sort of takes the fun out of having a bus conversion. Keep simple and reliable, must be reserved for us old seasoned campers, I guess.
Offline oltrunt
  • A fine BCM outting
« Reply #3 on: April 21, 2020, 12:30:11 PM »
I prefer having the macerater located just past the slice valve.  If it jambs up I'll just take it off and slap on a stinky slinky until I get another one.  Jack
Offline sledhead
« Reply #4 on: April 21, 2020, 01:09:09 PM »
I did the same kinda thing . I used a clear slinky 45% connector that goes to a 1/3 HP washing machine pump and then into a 1 1/2 " fire hose in 50 ' length's that will pump uphill to 10 ' and fast . if it craps out all I have to do is undo the clear slinky pipe fitting and install the old slinky .
dave
dave , karen
Offline Knuckles
« Reply #5 on: April 26, 2020, 07:19:53 AM »
I kind of think offmy macerater toilet and hot water on demand as reliable. Both being 12 volt iwould rather replace a fuse than try to break up a solid mountain of crap in my black tank and the only thing i have ever had go wrong with hot water on demand was running low on propane which is my fault. Just because they are a new way of doing things doesn't make them unreliable if done correctly. Sometimes us old guys have to try to make things easier and better
GM 4107 8V71  V730
« Reply #6 on: April 26, 2020, 08:30:48 AM »
I just replaced my 2-10gal electric water heaters after 26 years of use. I doubt that can be beat. Good Luck, TomC
Offline Fred Mc
« Reply #7 on: April 26, 2020, 09:16:03 AM »
My first camper had a macerator toilet that quit so I had to fix it. I PROMISED i would never have another.That was 40 years ago and I have faithfully kept that promise. :)
Online Dave5Cs
  • BCM Subscriber
« Reply #8 on: April 26, 2020, 10:02:46 AM »
Masadisposerator the only way to go. Stainless steel 3/4 hrp pumps up hill so far to 145 ft in length through a garden hose. :)
Offline chessie4905
« Reply #9 on: April 26, 2020, 10:23:44 AM »
How do you end up with a solid mountain of crap? Is this sitting in one place most of the time? Everything should be breaking down sufficiently in your black tank.
Offline richard5933
« Reply #10 on: April 26, 2020, 10:45:55 AM »
Best way to build a mountain of crap in your black tank is to keep the discharge valve open all the time while you're connected to sewer hook ups. The liquid will go away quickly, but there is not enough flow to carry the solids with it. Much better to let the tank get at least 1/3-1/2 full before dumping to make sure there is enough liquid to move things through.
Of course, on our combined gray/black tank we never have an issue with too little liquid.
Offline dtcerrato
« Reply #11 on: April 26, 2020, 05:18:49 PM »
We have a 3" slide valve on both gray & black tanks & another 3" slide after those two independent slides come together. That enables us to flood/flush the black tank with the gray tank. Works great.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline oltrunt
« Reply #12 on: April 26, 2020, 07:09:08 PM »
Ditto on that.  Jack
Offline Jim Blackwood
« Reply #13 on: April 27, 2020, 07:19:35 AM »
I was kinda toying with the idea of routing the gray water through the black water tank to flush, with a smaller water hose fitting to drain the gray into the grass. Anybody see any issues with that?
Offline richard5933
« Reply #14 on: April 27, 2020, 07:39:05 AM »
There are endless ways to route things, but for something like this I've always found that tried & true works. No need to reinvent the wheel for something as simple as draining tanks. If you are planning to use the gray water to flush out the black tank, then the standard Y adapter that many use works fine to flood the black tank - dump the black, flood the black tank with gray water, then dump the gray water.
Ours is even more simple, with a combined black/gray tank. Unless one is planning to dump gray to the ground, there is not a good reason to have them separated IMO. If you are planning to dump gray to the grass, be aware that the practice is not allowed in most places/campgrounds/etc. You can do it on your own land, but even then the practice is questionable unless it's done correctly.
