Author Topic: air compreesor rebuild engine  (Read 2748 times)
Offline richardkillmon
  • 954-778-6674
« on: July 13, 2020, 06:18:58 AM »
Hello,
I'm replacing my air compressor and noticed my alcohol canister is missing.
I don't plan on driving in cold weather but you never know.
Should I install the system?
Rick
1976 MCI 5B challenger MT-644
Offline lostagain
Re: air compreesor rebuild engine
« Reply #1 on: July 13, 2020, 07:11:46 AM »
I would install an air dryer, if you don't have one already.
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Offline Utahclaimjumper
« Reply #2 on: July 13, 2020, 08:01:51 AM »
 The only way to go,, it's a plus, cold weather or not :^ >>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline dtcerrato
« Reply #3 on: July 13, 2020, 04:39:05 PM »
10-4. We recently put a dryer in after 35 years of bus ownership & then wondered why it took so long! It didn't just dry the air up but also cleaned it up to. Compressor oil doesn't make it past the dryer.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline chessie4905
« Reply #4 on: July 13, 2020, 05:16:17 PM »
dryers dont like excessive oil. itll contiminate the dessicant. "
Consider a quality rebuilt compressor. get a good rebuilt one. the cheap rebuilds dont take long to start spitting oil again.
Offline benherman1
« Reply #5 on: July 14, 2020, 07:23:16 AM »
I'm in the same boat with a shattered alcohol reservoir. Any recommendations on what kind of dryer to use? As far as oil getting in some of what I've been reading up on says you can use a separate filter to remove oil before it gets to the air dryer.
Any reason to not just repair the alcohol evaporator?
1964 MC5A - 5289 - Bloomington IN
« Reply #6 on: July 14, 2020, 02:08:23 PM »
Bendix does not recommend using the Alcohol system anylonger they haven't for many years it make the rubber seals and diaphragms in the components' in the system degenerate over time .The knock off (aftermarket) AD-9 Bendix dryers can be purchased for around $150.00 ($104.00 less the brackets on Amazon) and they are not bad for a aftermarket part and easy to install keep you tanks drained  and don't worry about a inline filter
« Reply #7 on: July 14, 2020, 03:10:12 PM »
 Mine is a Haldex Pure Are Plus,, it's 23 years old and works with out fuss..  I have installed a new service kit twice and it just keeps on doing it's thing,, my automatic "spitters" never seem to drain any moisture.>>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline chessie4905
« Reply #8 on: July 14, 2020, 06:01:55 PM »
on the Bendix website, they dont generally recommend alcohol evaporators, as they accelerate breakdown of the rubber components.
