BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Brake lights stay on
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Brake lights stay on (Read 7641 times)
Mozz1k
Newbie
on:
November 05, 2020, 11:19:32 AM »
I recently bought a 2000 Prevost H3-45 to convert into a motor coach. Everything is great with it, but the brake lights stay on, and there’s an indicator light on that looks like the back of the bus. Does this have something to do with the parking brake? Need help. Ha.
Logged
Hero Member
Re: Brake lights stay on
Reply #1 on:
November 05, 2020, 11:42:23 AM »
Chock the wheels, Transmission in Neutral, start bus and release the Parking brake. Brake light still on? it should go out. There is a relay (probably in rear elec panel) to eliminate the brake light when parking brake is engaged. Light on dash is normal when ever service brakes are applied.
Logged
Mozz1k
Newbie
Reply #2 on:
November 05, 2020, 11:48:40 AM »
Okay! I’ll check for a relay. Yeah they stay on whenever the bus is running... parking brake on or off it doesn’t matter either way the brake lights stay on. I looked for anything in the way of the brake pedal, and pulled up on it.... still lights stay on.
Logged
niles500
Niles500
Hero Member
ROSIE
Reply #3 on:
November 05, 2020, 03:11:56 PM »
The indicator light might be the engine door ajar - hth
Logged
(\__/)
(")_(")
- Niles
Dave5Cs
Hero Member
BCM Subscriber
Reply #4 on:
November 05, 2020, 03:47:15 PM »
Is it fully aired up when it happens?
Logged
Mozz1k
Newbie
Reply #5 on:
November 05, 2020, 10:44:14 PM »
Whether it's fully air'd up or not. Tried pulling cycling the yellow air switch, also pulling up on the brake pedal. Checked the rear compartment. It is latched. I'm wondering if it has to do with a switch under the yellow parking brake handle? Wonder if there is a switch in there that indicates that the parking Brake is on?
Logged
Hero Member
Reply #6 on:
November 06, 2020, 05:38:44 AM »
Brake lights are applied by a number of pressure switches, both ones that come on with pressure, and ones that come on in the absence of pressure, depending on whether they are plumbed into service or parking systems.
One of them has shorted, or is being shorted across?
Your multi-meter, the schematic, and a hunt for them all to test...
Happy coaching!
Buswarrior
Logged
Mozz1k
Newbie
Reply #7 on:
November 06, 2020, 06:07:07 AM »
Thanks bus warrior!! I’ll see what I find out! I’m a rookie at this.
Best regards!
Logged
Hero Member
Reply #8 on:
November 06, 2020, 06:30:31 AM »
Check for sensors with one or two wires coming off the brake application valve. ( brake pedal). Underneath in under driver compartment. You should see several air lines connected to it and one or more sensors with wires. You can disconnect one of the wires and see if light goes off. Unfortunately on newer models, they frequently use that switch to activate a relay to energize the lamps, so could still be bad relay and switch is ok.
Logged
Mozz1k
Newbie
Reply #9 on:
November 06, 2020, 06:34:57 AM »
Ahh good to know!! I will deep dive into this this coming weekend! I will update and probably ask more questions as I go. Thank you !
Logged
niles500
Niles500
Hero Member
ROSIE
Reply #10 on:
November 06, 2020, 09:35:25 AM »
BTW, brake lights will be on if Jake/retarded are switched on
Logged
(\__/)
(")_(")
- Niles
Mozz1k
Newbie
Reply #11 on:
November 06, 2020, 10:59:25 AM »
Oh I had no idea about the Jake/retarder. I’ll make sure that’s off. I’m pretty sure that has been off. But I’ll double check
Logged
HB of CJ
Hero Member
Reply #12 on:
November 09, 2020, 12:01:16 PM »
Does the coach have a Jake? Did it once have a Jake? I think nowadays when the Jake is working the brake lites come on? Is this true? My Crown had a dash indicator light that came on when the Jake was operating but the brake lites did not come on. Long ago, far away. Could some relay be bad or just deleted?
Yeah with the idea of making sure the brakes are not dragging, even when not applied, setting off the brake on light. Good luck. I love figuring out this kind of stuff ... others hate it. Oh well.
Logged
Mozz1k
Newbie
Reply #13 on:
November 17, 2020, 11:27:26 PM »
So, I unhooked one of the wires that goes to the Yellow emergency brake handle. Lights still stay on. I contacted the place where I bought the bus. They suggested a couple of things that were mentioned previously. Lastly they said it is a short probably buried in the wiring.... and wished me luck. Ha! Sooo I might bring it to a diesel & pickup specialist and see what they suggest.
Logged
Mozz1k
Newbie
Reply #14 on:
November 17, 2020, 11:28:44 PM »
Also, transmission brake "Jake" brake was off. So that excludes that.... This is a head scratcher
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
