BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Extra door on Prevost bus
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Extra door on Prevost bus (Read 3323 times)
Codokrat
Prevost Project
Newbie
on:
November 08, 2020, 08:40:13 PM »
I just bought a Prevost Le Mirage XL-45 and I want to add an extra door in the back.
The thought is to remove the farthest back window and skin over it with aluminum. Then I should be able to cut a new door in the area using the existing skin to fit just between the window struts.
Has anyone tried anything like this?
The plan in the long run is to put a motorcycle lift in the new door so the motorcycle sits perpendicular to the bus just in front of the rear axles.
Logged
2000 Prevost Le Mirage XL-45
Passenger Conversion
Hero Member
Re: Extra door on Prevost bus
Reply #1 on:
November 09, 2020, 03:46:49 AM »
For inspiration and ideas, go crawl around one that has a wheelchair door and lift installed.
The various methods of strengthening can be backyard engineered to your own coach.
The very rear will require some thought on strengthening for the loss of the siding, with the engine also hanging back there.
Where there is a will...
Happy coaching!
Buswarrior
Logged
lvmci
lvmci
Hero Member
Reply #2 on:
November 09, 2020, 05:36:35 PM »
Hi Codokrat, before buying my 102C3, I was looking for a new era MCI with a wheel chair lift, modern motorized wheel chairs can weigh 700 lbs, with batteries, motors, electronics etc, which puts the weight in the big motorcycle category. By lengthening the ramp, I felt it was doable. The MCI factory lift has extra structural support that is needed for heavy wheel chairs or motorcycles...lvmci...
Here's the brand used by MCI:
ADA compliant with the factory Ricon Wheel Chair Lift.
Here's a picture of a D's wheel chair lift
Logged
MCI 102C3 8V92, Allison HT740
Codokrat
Prevost Project
Newbie
Reply #3 on:
November 09, 2020, 08:24:18 PM »
I'll look into a wheel chair lift, I wasn't too worried on the lift itself, just the opening, but if that comes with reinforcement it may be ideal.
Logged
Hero Member
Reply #4 on:
November 10, 2020, 04:12:29 AM »
Be good if you could find one being scrapped that you could get the opening and all associated components, or at least check it out. Maybe MCI has images in the factory parts or service manual. Sombody here that can check?
Logged
hogi6123
Full Member
Reply #5 on:
November 10, 2020, 05:36:24 AM »
I'm taking apart a MCI 102dl3 with a wheelchair lift halfway back. It looks like it's not factory original. There's not really any extra bracing added. We took off the skin, I can post a few pictures if you'd like.
Logged
1981 MC-9
Codokrat
Prevost Project
Newbie
Reply #6 on:
November 10, 2020, 07:18:32 AM »
yeah, if you can post pics that'd be great, I haven't found much for aftermarket wheelchair lifts on Prevosts
Logged
robertglines1
steam nut
Hero Member
Reply #7 on:
November 10, 2020, 12:16:46 PM »
Couple of observations here. I have seen bikes transported on the front of a of a tow dolly still functions as toe dolly with vehicle there also. 2nd have had friends just use special battery on bike and oil caps/fuel and build slide and lay bike down and haul laying down.. On a xl the tounge weight on a standard engine cradle can not exceed 750 lbs. Hd cradle required for more about 10 grand. You could easy spend 5 time the hrs inventing something than on the rest of the conversion.. (been there on this one). I like the challanges my self but then I'm Nuts. The frame in front of drive axle is pretty close to outside. Would be possible to set motocycle in length ways of bus. Fuel tank comes to front side of last bay. Evaporator bay(area)is only about 24 inches deep before fuel tank .. I can get you some measurements off mine if you need it.
Logged
Bob@Judy 98 XLE prevost with 3 slides --Home done---last one! SW INdiana
hogi6123
Full Member
Reply #8 on:
November 10, 2020, 01:48:51 PM »
OK, here are pictures of the wheelchair lift door on my MCI 102DL3.
I cannot say whether this was good or not (besides the obvious lack of proper waterproofing), I can just show you how someone did it.
The door itself was constructed out of aluminum square tube.
Logged
1981 MC-9
hogi6123
Full Member
Reply #9 on:
November 10, 2020, 01:49:45 PM »
More photos.
Reinforcement was added into the roof structure, but none below the floor.
Logged
1981 MC-9
hogi6123
Full Member
Reply #10 on:
November 10, 2020, 01:50:06 PM »
More photos
Logged
1981 MC-9
Hero Member
6 Setras, 2 MCIs, and 1 Dina. Just buses ;D
Reply #11 on:
November 12, 2020, 04:06:51 PM »
For used MCI stuff try Sam Caylor @
Caylor Supply
Address: 4712 Rock Creek Rd, Rantoul, KS 66079
Phone: (785) 878-3405
(Kansas City area)
He's been buying and selling MCI's and parts for years!
BK
Logged
Keep SMILING it makes people wonder what yer up to!
(at least thats what momma always told me!
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
