Author Topic: Inverter issue -- they say generator dirty wave  (Read 4973 times)
Offline richardkillmon
  • 954-778-6674
« on: December 11, 2020, 12:54:19 PM »
Hello to all,
I have an year old Onan 10K generator and a MasterVolt inverter issue.
On shore power the inverter works perfectly but on generator power the inverter start a 2 minute cycle over and over again. It starts out Bulk charging for 2 minutes (normal) and the charger shuts off for 2 minutes and then back to normal for 2 minutes.
MasterVolt states that my generator frequency wave is close but not perfectly clean and I need to filter the power.
Generator company has checked unit twice and all is normal.
Has anyone heard of this before?
What kind of filter do I add? UPS??
Is it the inverter or my generator?
What can I do?
Rick
1976 MCI 5B challenger MT-644
Offline Utahclaimjumper
Re: Inverter issue -- they say generator dirty wave
« Reply #1 on: December 11, 2020, 01:09:45 PM »
 It looks like your talking about a CONVERTER,, or possibly an inverter/ converter.. An inverter changes 12VDC to 120 V AC .>>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
  • 954-778-6674
« Reply #2 on: December 11, 2020, 01:17:32 PM »
Yes, I have a 4 AGM batteries that supply my outlets with 120 outlets once the inverter does it magic.
« Reply #3 on: December 11, 2020, 01:23:13 PM »
Does it have a battery temperature sensor? my Magnum went crazy and Magnum sent me a new battery sensor to solve the problem
  • 954-778-6674
« Reply #4 on: December 11, 2020, 01:27:28 PM »
Yes has battery sensor.
The Inverter tech checked all settings and wires for any errors - none.
Offline buswarrior
« Reply #5 on: December 11, 2020, 04:40:58 PM »
Get a "kill-o-watt" off Amazon, and check the hertz of your generator.
Generators don't make "dirty" power, that phrase is reserved for old, choppy, modified wave inverters.
Curious what the generator voltage is doing when the device in question is getting messed up?
Happy coaching!
Buswarrior
  • 954-778-6674
« Reply #6 on: December 11, 2020, 04:46:44 PM »
thanks
  • 954-778-6674
« Reply #7 on: December 11, 2020, 06:43:18 PM »
60 Hertz
« Reply #8 on: December 11, 2020, 06:55:32 PM »
It don't get any better than that,, does the generator bogg down a bit when under load ?? >>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
  • 954-778-6674
« Reply #9 on: December 11, 2020, 07:07:23 PM »
The RPMs never change on it
« Reply #10 on: December 12, 2020, 08:49:24 AM »
 That means your frequency never changes and that's a good thing.>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline RichardEntrekin
« Reply #11 on: December 13, 2020, 04:37:27 PM »
Is it possible that the transfer switch is flaky, and not passing clean power to the inverter/charger?  Can you temporarily wire around the xfer switch?
Richard Entrekin
2007 Marathon XL II
Ford Maverick Hybrid Toad
Inverness, Fl
  • 954-778-6674
« Reply #12 on: December 13, 2020, 04:41:54 PM »
I have a manual transfer box that I turn to left for shore power or right to generator power.
Should I bypass this? Could the contacts be corroded?
Rick
Offline richard5933
« Reply #13 on: December 13, 2020, 05:32:17 PM »
Rick
Rather than bypass, you might confirm that all the terminals are fully seated and tight, even the ones on the bottom. There will likely be 9 terminals in all (L1, L2, and Neutral for each Generator, Shore Power, Line Out to Breakers).
The terminals can get loose over time and the result is often what you're describing. When you test them for being tight, be sure to give them a good crank - they can stick in place after a few years and you'll think they're tight, but another 1/4 or 1/2 turn might be possible once they break free.
  • 954-778-6674
« Reply #14 on: December 13, 2020, 05:37:45 PM »
thank you for that help.
