BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Zerk Panel Copper Tube Size?
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Zerk Panel Copper Tube Size? (Read 8014 times)
brianzero
Full Member
MCI-9 / 6v92 / 5 Speed
on:
December 31, 2020, 08:49:25 AM »
Hi All,
The master zerk lubrication panel is connected to several copper tubes that carries grease to its destinations, and in my case, one of them has a rupture. What size are these copper tubes, and might they be common at the hardware store?
Logged
richard5933
Hero Member
Re: Zerk Panel Copper Tube Size?
Reply #1 on:
December 31, 2020, 08:58:12 AM »
Can you take a caliper to get the OD of the tube? I'd bet that it's a standard size and that it uses standard sized fittings on the ends.
Logged
ol713
Sr. Member
Reply #2 on:
December 31, 2020, 09:07:27 AM »
Hi;
If you can remove it, take it to a Napa dealer for a "show and tell". Let them tell you what your options are.
Logged
sledhead
Hero Member
Reply #3 on:
December 31, 2020, 09:10:33 AM »
or a easy way to find the size od of the tube is use a open end wrench and the one that fits has the size stamped on the wrench 1/4" 3/8" and so on
dave
Logged
dave , karen
1990 mci 102c 6v92 ta ht740 kit,living room slide .... sold
2000 featherlite vogue vantare 550 hp 3406e cat
1875 lbs torque home base huntsville ontario canada
Jim Blackwood
Call me Doc, or call me arsehole, just don't call me late to dinner.
Hero Member
I'm 25% Farnsworth ;-)> 1996-MCI 102DL3
Reply #4 on:
December 31, 2020, 09:29:05 AM »
I used 1/4" when I did this but the stuff they sell at the box store is too thin these days. It probably won't hold up well. Instead you can use 1/4" brake line tubing which is thicker and if you want it to be easier to work and look like copper use the Ni-Copp version which also won't rust. Wish I'd thought of that.
Logged
brianzero
Full Member
Reply #5 on:
December 31, 2020, 09:37:38 AM »
My best guess without a caliper would be 1/4", and brake line tube would probably work just as well as copper. As long as the ends of the tube need to be flared like a brake system, I think that solution would be best.
Logged
Jim Blackwood
Hero Member
Reply #6 on:
December 31, 2020, 09:51:03 AM »
I put 1/4-28 threads on one end of the tube. Now this was tricky because of the thin wall so what I did was to screw a nut on to the copper tube to swage the threads because a die just wouldn't work. With the hardware store line it wanted to collapse which meant I couldn't screw the nut on quite as far as I'd have liked. With the ni-copp I think that would not have been a problem. With steel line I'm not sure you could do it, but the die might work.
The holes in the jack that the zerk screwed out of were 1/4" and I didn't find any flare fittings to match that. On the other end it's easy, just use the NPT zerks and a flare or compression adapter fitting.
Logged
richard5933
Hero Member
Reply #7 on:
December 31, 2020, 11:00:59 AM »
It shouldn't be necessary to reinvent the wheel for these, as it's quite common to use remote Zerk fittings. The reason I mentioned measuring is that there obviously more than one size used.
You can also replace the copper lines with something like this:
https://locknlube.com/products/grease-fitting-relocation-kit?variant=1691361542168&utm_source=google&utm_medium=cpc&utm_campaign=CedCommerceGoogleShopping&gclid=CjwKCAiAirb_BRBNEiwALHlnD8_MNk-PZH5dbq6FrgtdIg4ai-O8tzRF-uoihwYP1N5XKcM2hbE37xoC4sYQAvD_BwE
Logged
Hero Member
Reply #8 on:
December 31, 2020, 11:33:10 AM »
It's nothing special I replace those with brake lines from NAPA or O'Riley's brake lines will take more pressure than the copper lines
Logged
brianzero
Full Member
Reply #9 on:
December 31, 2020, 11:38:01 AM »
And do you flare the brake lines to connect them? How are these connected? Compression fittings?
Logged
Hero Member
Reply #10 on:
December 31, 2020, 12:48:17 PM »
Quote from: brianzero on December 31, 2020, 11:38:01 AM
Flare when needed just like the copper
Logged
Jsrcaptain
Jr. Member
Reply #11 on:
January 01, 2021, 06:07:52 PM »
Check out the silicon/bronze brake lines. Same size as the steel lines, but very easy to bend and flare. Made for brake pressure so should handle a little grease easily.
Logged
1972 MCI MC5B, 8V71 NA
Baraboo, Wisconsin
dtcerrato
Hero Member
Reply #12 on:
January 01, 2021, 08:31:47 PM »
Silicon bronze is awesome material & double flares well too.
Logged
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Jim Blackwood
Hero Member
Reply #13 on:
January 02, 2021, 09:33:02 AM »
I've not used the silicon bronze but I suspect it is very much like the nickel/copper in use. May be a bit more expensive but I'm not sure.
Logged
Jim Blackwood
Hero Member
Reply #14 on:
January 02, 2021, 11:19:27 AM »
Where are you guys buying your silicon bronze tubing? I can't find it.
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
