Author Topic: Air filter for 6v92  (Read 1404 times)
Offline Jkirk1122
Air filter for 6v92
« on: January 10, 2021, 02:58:38 PM »
Where can I find a replacement air filter for a 6v92? Losing power and blowing black smoke when I throttle up. Anyone know a part number? I would just look but not with the bus at the moment. Thanks
Offline chessie4905
Re: Air filter for 6v92
« Reply #1 on: January 10, 2021, 03:07:00 PM »
Check over first. Could be bad turbo or loose connections, blocked exhaust,etc. You could also temporarily disconnect filter if it can be easily done and see if it runs fine then. Should put some screen over inlet so you don't suck in any debris, birds, mice, cats, etc.
« Reply #2 on: January 10, 2021, 03:27:50 PM »
Your S10 Eagle will have the Farr filter from the factory mounted on passengers side in the engine compartment won't be a round filter if it's original
Offline Jkirk1122
« Reply #3 on: January 10, 2021, 03:50:18 PM »
It has the big, fat round one....so I’m guessing not original
