Author Topic: looking for a 8v71 detroit diesel engine for '61 PD4106  (Read 10378 times)
Offline wobbleman
Re: looking for a 8v71 detroit diesel engine for '61 PD4106
« Reply #30 on: May 07, 2021, 12:05:16 PM »
Re: engine for a 4905 in central PA
I believe I have the same problem and will probably need to swap in a new engine in my 4905A. Any info on the engine in PA mentioned?
Also: what would you expect to pay for one?
Offline matzeinusa
« Reply #31 on: May 08, 2021, 02:27:55 PM »
The one in MI was $1400 turbo without transmission.
Contact cheesie directly for the PA one.
Matt
Offline Tedsoldbus
  • Life is not a rehearsal. Get your bus on the road.
« Reply #32 on: May 08, 2021, 03:57:26 PM »
Damn Matt,
Us none mechanics know to shut up and watch the wizzards try to help you. But know that we do watch with great fascination hoping to learn something. I was sure someone would pull a rabbit, or motor, out of their hat. I will have to be nicer to my 6V92 if motors are drying up. And now a moment of silence as another asphalt annihilator sadly goes off the active bus rolls.
Best of luck finding another bus.
1980 shorty (35') Prevost
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
Offline richard5933
« Reply #33 on: May 08, 2021, 05:52:51 PM »
Maybe I missed something, but is the bus otherwise in good shape? Or is it so bad that there is no point doing an in-frame to bring it back to life?
Offline Dave5Cs
  • BCM Subscriber
« Reply #34 on: May 08, 2021, 06:23:42 PM »
Matt have you tried these guys in West Sac. They had a 4106 that they rebuilt years ago and the guy never came back. Don't know if they still have it but I know they have 2 strokes or may know who does.
https://www.valleypowersystems.com/
Offline freds
  • 1980 Prevost Original Motorhome
« Reply #35 on: May 09, 2021, 01:36:17 PM »
If they can't do an in-frame what is the differences between a LH and RH engine? I would think:
1. Cams
2. Starter
3. Blower
Could they not be transferred between the original and replacement engine?
« Reply #36 on: May 09, 2021, 02:47:01 PM »
Cams,oil pump;idler gear and starter if you have the right crank shaft the blowers are the same
Offline wobbleman
« Reply #37 on: September 03, 2021, 04:53:06 AM »
Sounds almost exactly like my own situation (1978 P8M4905A).
 I assumed that opening all the draincocks would drain ALL the coolant. It did pop a freeze plug but now I'm seeping coolant into the oil, so either a crack or seals.   I had also overheated it, driving the long road up to Taos NM ,and had to change the top head gasket. Probably did some damage then, too.
One question: I read that these buses were designed so the engine could be changed out it a few hours. Is that right?
Whoever posted that it makes more sense to start over... I hate to admit it, but you're probably right. I only Paid $2500 for it 10+ years ago.
Anyone have use for a decent shell, CHEAP? Located in NY State. Previous owner worked for Grumman, assembling aircraft and did a beautiful job on the alterations he made to the skin- can't even tell they aren't original!
And I cringe to even mention it, but what is my approximate scrap value?
Wobbleman
