Author Topic: Gear Ratio for 4107 GM bus  (Read 4252 times)
« on: May 20, 2021, 05:13:16 AM »
What is the tallest rear gear ratio you can find for a 4107 GM this one tops out at 64 mph @2100 rpm with the V730.it will have enough power to handle the higher gear so that is not a problem
Offline Runcutter
    • Runcutter.com
Re: Gear Ratio for 4107 GM bus
« Reply #1 on: May 20, 2021, 08:05:20 AM »
Clifford, my 4107 manual only shows 4 1/8 to 1.  Parts Book shows 4 1/8 to 1; 4 3/8 to 1; and 4 5/7 to 1.  Also a 5 3/6 to 1, a ratio I've never heard of.
I tried to attach copies of the two pertinent pages, hopefully they'll attach successfully.  If not, let me know ant I can email them.
Arthur
Offline Utahclaimjumper
« Reply #2 on: May 20, 2021, 12:17:35 PM »
 Highest I've seen is 4 1/8,, to get more go to 24.5 wheels..>>>Dan
 ( Mikey has 4 1/8 with 24.5s + V730 and is happy.)
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #3 on: May 20, 2021, 04:03:01 PM »
a
It has 12rx22.5 tires now not much to gain with 24.5 wheels with 11rx 24.5 tires  best I can tell it has the 4-1/8 so I will be looking at different ratio torque converter I guess
Offline chessie4905
« Reply #4 on: May 21, 2021, 06:31:53 PM »
about 4mph between the two ratios. 4:12 and 4:27. Mine would go about 74@ 2450. Has 4:27  in it. Have the 4:12's to install.
different ratio torqueconverter will effect starting out but no difference after locked up. Dont have Allison book handy, but they list 2 ratios for V730. I know the 740 have several ratios.
Offline RJ
  • Vantaré Conversion "Miss Vivian"
« Reply #5 on: May 22, 2021, 12:09:18 AM »
Cliff -
The stock rear axle ratio, like Arthur said, was 4.125:1.  Coupled with the four-speed manual's 0.808:1 bevel gear ratio, that gave an overall rear axle ratio of 3.333:1
Pulling the 4-spd and installing the V-730 changes the overall ratio because of the different bevel gears in the automatic. This equates to 4.125 x 0.875 = 3.609:1, not quite 10% lower than the 4-spd.
The 4905s came stock with a 4.375:1 rear axle ratio, which, combined with the 4-spd equaled a 3.535:1 overall ratio. (This equates to a 100 rpm difference in 4th gear at 60 mph between the 35' and 40' Buffalos.)
If somebody takes a stock 4905 and swaps in the V-730, they end up with an overall ratio of 3.828:1 (4.375 x 0.875)
Interestingly, if an operator ordered a late ('77 and later) model 4905 with the V-730, GM installed the 4.125 rear axle with this combination!
Finally, in all the research I've done over the years, installing 11R24.5 drive tires that turn 470 revs per mile on a coach with the V-730 and a 4.125 axle will provide an overall ratio of about 3.510:1, the closest compromise I've seen.
FWIW & HTH. . . ;)
« Reply #6 on: May 23, 2021, 08:20:01 AM »
The v drive must be power hog for a light weight bus to be that low of a gear ratio you see old T drive with 8V71 NA engines  with 3:36 and 3:36 gears lol even some with 6v71
« Reply #7 on: May 23, 2021, 10:45:21 AM »
 80MPH is the new 65..>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
« Reply #8 on: May 23, 2021, 11:49:29 AM »
You. should be able.to run 65 mph at 1700 to 1800 rpm with a 2 stroke they do not like a steady diet of.2100 and 2300 rpm everyday of  their life
Offline Dave5Cs
  • BCM Subscriber
« Reply #9 on: May 23, 2021, 01:12:29 PM »
We were hitting 71 yesterday on I-10..... :^
Offline chessie4905
« Reply #10 on: May 23, 2021, 03:17:57 PM »
8-71's are like a honey badger. they dont give a dam how long you run them at 2100 to 2300. 92's thats a different story.
coach still starts fine without a low gear.
« Reply #11 on: May 23, 2021, 08:29:40 PM »
.   They don't bleed as much at 1700 to 1800 rpm for sure
Offline RJ
« Reply #12 on: May 24, 2021, 12:58:56 AM »
Dave -
Did you see the message I sent you back in April???
Offline chessie4905
« Reply #13 on: May 24, 2021, 07:25:11 AM »
Yeah, you pound one at 2100 all day long, youll see leaking getting worse. Funny nobody spends the money on a Walker Air Sep to eliminate the leaks. Used a lot in boats to keep the bilge clean and dry of oil. They are pricey though.
GM has used a smaller version on their diesels since 1981 on the 5.7. Really made a difference on leakage. Used clear up to today on at least on Duramaxes. CDR- crankcase depression regulator valve.
« Reply #14 on: May 24, 2021, 04:55:06 PM »
With 11R-24.5, V730, 4.56 rears, 60mph is right at 1,900-of which is my usual cruising speed. Good Luck, TomC
