Author Topic: Guy is Broken Down in Arlington, VA and has a question.  (Read 2927 times)
  • Publisher - BCM
  • Administrator
    • BCM
« on: August 01, 2021, 06:57:27 AM »
I was sent this from Eric Lindgren who has an MC-9 8V71, broken down at the Exxon in Arlington, VA.  Can anyone give him any ideas?  Here is his request.
I'm broke down on the side of the road, (8v71) it keeps saying low oil, but the pressure is off the charts.
He said he was able to limp it in with zero throttle to the parking lot.
He will monitor the Forum, but is not officially a member yet, he is waiting for approval from Phil who is out of town this week.
Does anyone have any idea what could be causing this and what he should check?
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
Re: Guy is Broken Down in Arlington, VA and has a question.
« Reply #1 on: August 01, 2021, 07:28:23 AM »
Also received this from Eric as well:
To: Phil Lyons <phil@busconversionmagazine.com>
Subject: Re: Bus conversions BBS Join Request
My 1980 MC-9 with a 8v71 is broke down on the highway with a low oil light. The oil is fine, it was just changed.
 I plan on dropping the pan, and checking the pick-up for debris. I already deleted the oil to the alternator/generator. No leaks, current level reads full... I don't know what else it could be
Offline thomasinnv
  • Derrick Thomas
« Reply #2 on: August 01, 2021, 07:42:37 AM »
There should be two oil pressure senders on the oil manifold left side of the engine, probably mounted on top of the engine rail. One is to the pressure gauge, other one is a 3psi switch that activates the low pressure light and engine shut down. Sounds like a bad switch if you have good oil pressure. Unplug the wire to the 3psi switch and that should eliminate the light and shutdown. If he has good oil pressure there is absolutely no reason to drop the pan.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
« Reply #3 on: August 01, 2021, 07:49:55 AM »
He should have a manual gage on the engine rail drivers side if reading oil pressure there disconnect the Kysor sending unit
Offline Erik L.
« Reply #4 on: August 01, 2021, 08:06:40 AM »
It seems to be working. I will see how far this takes me. I'm glad I slept on it, rather than dropping the pan. Thank you so very much folks.
Offline Erik L.
« Reply #5 on: August 01, 2021, 08:13:11 AM »
I'm not getting any throttle control still.
Offline Erik L.
« Reply #6 on: August 01, 2021, 08:18:42 AM »
I may have it, I'll let y'all know. Bless y'all.
« Reply #7 on: August 01, 2021, 08:22:12 AM »
Maybe the fast idle is turned on by accident
Offline Ed Hackenbruch
« Reply #8 on: August 01, 2021, 10:19:38 AM »
Had that happen to me one time.  Going down the freeway in Colorado, had a dog that came running towards us so i reached up to pull the air horn cable to scare it away. Right after that i realized that i had no throttle, pulled over, got out, went to the back and opened up the engine doors and realized it was running faster than normal idle. Went back and found that i must have brushed my arm against the switch when taking my arm off the wheel and going for the air horn. Never even felt it. :)
Offline ol713
    • ol713
« Reply #9 on: August 01, 2021, 10:48:12 AM »
  you said the "oil was just changed" - - - -  did you use the correct oil? Might be a silly question,   but have to ask the obvious.
Offline Erik L.
« Reply #10 on: August 01, 2021, 03:32:11 PM »
Unplugging the bad sensor, is what fixed the issue. So simple, probably why I never considered it. This is my first diesel. I really appreciate y'all. Thanks again, everyone!  ;D ;D 8) ;)
Offline dtcerrato
« Reply #11 on: August 01, 2021, 05:38:56 PM »
Aren't ya glad you didn't pull the oil pan! You done great coming to the board.  :^
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline Erik L.
« Reply #12 on: August 01, 2021, 07:26:44 PM »
Yessir! Something told me to wait. I'm glad I did.
Offline Busted Knuckle
« Reply #13 on: August 30, 2021, 12:04:04 PM »
Now just be sure you use the right oil when changing it! Straight 40W no 15/40 as multi weight oil breaks down and give low pressure when it gets hot in a 2 stroke!
