Have you tried the Amish in Shipschjwanna. They can make you one to fit.
I've been running searches for fridges. If I had 64" of height to work with I'd probably already have one but I'm limited to 60-7/8".
I...Paying the Almish $1500+ probably wouldn't be, and certainly a retail price of 3-4 grand is out of reach. ...Jim
RJ that is the only fridge I ever used one needs to run the ac units to make it cool enough to work, it tells you in the instructions not to build those in and install in a area where the temps are not above 82 degrees.I am glad yours worked mine was a piece of junk so was Tom and Doreen Caffery's
We have the side by side Amana it takes 3 amps,I don't care for it since it a cabinet depth but Sonja like the cabinet depth fridges
Is that 3 amps AC or DC? If it's AC, how much does it draw your batteries down through the inverter?
