Author Topic: What size is it?  (Read 1631 times)
Offline epretot
What size is it?
« on: August 30, 2021, 10:14:27 AM »
I want to solder a cap to these locations. 1 1/4 copper cap is too tight.
2000 MCI 102 DL3
Loveland, OH
Offline epretot
Re: What size is it?
« Reply #1 on: August 30, 2021, 10:15:35 AM »
The plumb and hvac supply house were both stumped
2000 MCI 102 DL3
Loveland, OH
« Reply #2 on: August 30, 2021, 10:31:55 AM »
That is commercial refrigeration tubing size,I bought some Hussman
Offline dtcerrato
« Reply #3 on: August 30, 2021, 10:35:50 AM »
It almost looks like a "Pex" fitting which ARE! a bustard size. Ask me how I know! You may want to inquire or search 1-1/4" Pex to see what you come up with. Just a guess and an issue I ran into with the same looking fitting in 1" size.
Hope that might help...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline Jim Blackwood
« Reply #4 on: August 30, 2021, 12:44:32 PM »
Sometimes copper tubing swells, especially during freezing temperatures if they have water in them. A cheap set of digital calipers are your friend here if they go to 3 decimal places. You can compare to the new size. If it's just tight but you think it could be made to fit then the tubing has probably swelled. That's not the end of the road as there are many many ways around the problem. Easiest is most likely a rubberflex coupling for lower pressures and I would expect those to work fine for cooling runs (engine radiator and heaters). A tool can be found or made to swage the tubing back to the correct size. The fitting can be expanded to fit the tubing. Or sometimes a compression or other (PEX) type fitting can be used. My choice would be to drive the copper fitting on after cleaning both pieces and then braze them using a fluxless brazing rod for copper plumbing. A propane torch with MAP gas should get hot enough if you don't have an acetylene plumber's torch.
Offline Utahclaimjumper
« Reply #5 on: August 30, 2021, 12:55:43 PM »
 Are they presently soldered joints or welded,, you could always just measure the OD and fabricate a cap and use JB weld as a welded joint..>>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #6 on: August 30, 2021, 02:04:48 PM »
You can buy freeze plugs for the inside OD they don't have to be copper to solder either
