All that can be transferred over you are talking about a MCI trunnion mount I think, just weld a cross member and use the oil pump motor mounts works fine or transfer the trunnion mount,both engines will have the same oil pump on the front of the block outside the oil pan.Photos of the bell housing arrangement would help, MCI is strange with the 70 degree tilted air compressor and you may need to change back plate and relocate the auxiliary drives ,some MCI have the rear mount on the transmission some have the mount on the bell housing with no transmission mount,this what I do when I install a 8v92 in a older MCI because the trunnion mount won't clear the harmonic balance on the 8v92 ,I need to cut the rest of the trunnion out since he decided he wasn't keeping the factory air
