Author Topic: Jabsco macerator  (Read 3429 times)
Offline richardkillmon
  • 954-778-6674
Jabsco macerator
« on: September 17, 2021, 04:22:06 AM »
I have a Jabsco macerator toilet and I have T-paper clogging it.
I using two ply paper that is not RV two ply, is this my problem?
Must I use two ply RV paper or is it the toilet?
I remove the paper from the blades and they are hard plastic.
Have anyone else had this issue?
Rick
1976 MCI 5B challenger MT-644
Offline buswarrior
Re: Jabsco macerator
« Reply #1 on: September 17, 2021, 05:42:39 AM »
Put a couple squares of the offending toilet paper in a jar of water and close the lid. Let  it sit awhile, and then have a look, give it a shake.
"RV toilet paper" is a conspiracy...
Happy coaching!
Buswarrior
Offline Utahclaimjumper
« Reply #2 on: September 17, 2021, 05:49:04 AM »
If you always use "septic safe" paper, you will be fine..>>>Dan ( look on the label)
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline chessie4905
« Reply #3 on: September 17, 2021, 03:16:03 PM »
use Scott 1000 sheet toilet paper. Been using it for years. Wont clog. Leave the Charmin on the shelf. Problem can be many women want cloud soft 10 ply. Tell them tough, rough it.
Offline dtcerrato
« Reply #4 on: September 17, 2021, 05:35:28 PM »
Big hemlock leaves work great in a pinch! :o
Dan & Sandy
North Central Florida
PD4104-129 since 1979
« Reply #5 on: September 17, 2021, 05:39:25 PM »
 WHAT!! You don't keep a catalog handy.>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline epretot
« Reply #6 on: September 17, 2021, 08:55:18 PM »
Scott paper? Isn't that the same thing as John Wayne paper?
Rought and tough and don't take crap of nobody.
2000 MCI 102 DL3
Loveland, OH
Offline richard5933
« Reply #7 on: September 18, 2021, 02:42:49 AM »
Is the problem the type of paper?
Or too much paper?
Or too little water?
Offline Knuckles
« Reply #8 on: September 18, 2021, 04:51:26 AM »
I have a johnson pump macerater toilet and it eats anykind of toilet paper. It maybe as someone else said that it isn't getting enough water. Get an adjustable water pressure regulator and bump the pressure up to 50psi   That is what mine is set at and it gets lots of water and will grind up anything. It never fails to amaze me lol
GM 4107 8V71  V730
« Reply #9 on: September 18, 2021, 07:46:41 AM »
Costco TP is septic safe.
Offline Dave5Cs
  • BCM Subscriber
« Reply #10 on: September 18, 2021, 07:56:04 AM »
You need a Masadisposerator. It does not care what goes through it. 12 years and keeps on going.
« Reply #11 on: September 18, 2021, 08:15:04 AM »
 A water pressure regulator will NOT "bump" up anything,, if you have a 40 pound delivery, it will not give you 50 pounds of pressure.  It takes a PUMP to pressurize water..>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline chessie4905
« Reply #12 on: September 18, 2021, 03:51:25 PM »
He is probably talking about outside water source that bypasses on board pump and fresh water tank.
« Reply #13 on: September 18, 2021, 05:54:48 PM »
 That's not what was written..>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
 72 VW Baja towed
Offline chessie4905
« Reply #14 on: September 18, 2021, 07:03:59 PM »
Maybe,but if outside water source is reduced from 80psi at spigot to30 for coach water system, adjusting the regulator up to 50 would flow more water. But...ahh nevermind.😳
