Author Topic: Receiver hitch for MCI D3  (Read 8127 times)
Offline Sebulba
« on: January 28, 2022, 01:55:58 AM »
Hello All,
In about 3 months we need to pull out of Santa Fe and head to Montana.  I would like to tow our car, so that my lovely wife can navigate and relax by my side in the bus.
I can't seem to find a ready made hitch, so am contemplating having a local welder fabricate one.  This one pictures seems like a good design.
I'm guessing that about 3/8 steel would be about right for the plates that bolt on the bus.
Any input form you is welcome and helpful.
Thanks a million,
Seb
Bought a 1997 MCI 102D3 with Allison B500 on November 17, 2021 in Syracuse, NY.  Commenced living it that day and  drove it to Florida and New Mexico.  Converting as we go.  https://myvintagehat.com/
Re: Receiver hitch for MCI D3
« Reply #1 on: January 28, 2022, 03:35:35 AM »
That is about all you can do for a hitch on the MCI,looks like the same as the hitch MCI sold for awhile on the conversion shells .3/8ths thick may be a overkill the metal you are bolting too is not that thick
Offline sledhead
« Reply #2 on: January 28, 2022, 04:34:14 AM »
way back in the day I got a universal reese trailer hitch from walmart . it was easy to use on the 102c3 but took some time to install and the + was there was a lot of spare parts left over for other jobs
dave , karen
Offline Sebulba
« Reply #3 on: January 28, 2022, 08:08:35 AM »
Hmmmm, This is interesting.  Details...  Which hitch?  What di you mount it to.  Only bolt on?
Maybe something like this:  https://www.walmart.com/ip/Reese-Towpower-Class-III-Multi-Fit-Hitch/1957059
I do have two tabs hanging down form the engine cradle I think.  That I though about mounting a receiver to, but though this setup I found would be better.
Seb
Offline Dave5Cs
  • BCM Subscriber
« Reply #4 on: January 28, 2022, 08:14:20 AM »
yep same one that is on my MCI5C. They work well :^
Offline sledhead
« Reply #5 on: January 28, 2022, 09:14:31 AM »
ya
thats the one but way back in 2005 it was $98
dave , karen
Offline Sebulba
« Reply #6 on: January 28, 2022, 09:47:31 AM »
Sounds interesting,
Is it just a bolt on installation then?  To the bumper mounts?  To the Engine Cradle?
Pictures?  Anything would help.
I have limited tools and such at the moment.  So really interested in the details of installation.
No point in reinventing the wheel if you have a proven method.
Thanks a million.
Seb
« Reply #7 on: January 28, 2022, 10:09:13 AM »
Those so called tabs run the.length of the cradle on both sides for support I wouldn't attach a hitch there ,I would spend the bucks and go with your 1st idea it's a better setup.When you remove the bumper you will find a lot of cracks that will need to be repaired anyways it's a MCI
Offline Sebulba
« Reply #8 on: January 28, 2022, 12:13:39 PM »
Hmmm, ok, thanks, so it sounds like it's a good thing I found a welder...
Seb
Offline peterbylt
« Reply #9 on: January 28, 2022, 01:23:24 PM »
Had a local fabricator build this one for us, thought it came out really good.
Peter
Tampa Fl,
1989 MCI 96A3, 8V92TA
Offline Sebulba
« Reply #10 on: January 28, 2022, 01:29:17 PM »
Peter
Yeah, that looks nice.
2 Receivers?
How much are you into it for?
I wonder if the measurements would be the same for a '97 D3?
Thanks for sharing.
Seb
Offline peterbylt
« Reply #11 on: January 28, 2022, 02:16:27 PM »
2 Receivers?
Thanks for sharing.
Seb
If you look in the back of the pickup truck you can see the motorcycle/Bicycle rack that uses the second receiver, it was just too wobbly with only the one.
The fabricator, a good friend, charged me, IIRC about $200, but I paid him $300.
Our Bus is a 96A3, so 96 inches wide, so not sure if the measurements would be correct for you, the engine cradle mounts should be the same.
Thought I had the original design sheet I gave to the fabricator with all the measurements, but this was all I found, he didn’t follow my design anyway, he only had a 3” piece of square tubing so he used that instead of the 2”.
Peter
Tampa Fl,
Offline Sebulba
« Reply #12 on: January 28, 2022, 02:22:54 PM »
Peter
I was wondering if it was for a bike rack or something.
I have found a welder here in Santa Fe that I hope to get together with soon and talk about this project.
For the plates that bolt onto the bus, did you use 1/4 steel or?
Seb
Offline peterbylt
« Reply #13 on: January 28, 2022, 02:37:08 PM »
Seb
He used 1/2 inch steel for the plates, because it was what he had sitting around the shop.
Peter
Tampa Fl,
Offline Sebulba
« Reply #14 on: January 28, 2022, 03:38:45 PM »
Peter
Ok, that's good to know, that puppy must be heavy.
thanks
Seb
