Author Topic: 4106 brake relay valve  (Read 1804 times)
Offline fortyniner
« on: February 18, 2022, 04:07:14 PM »
Can someone point me to the modern replacement for the rear brake relay valve for 4106. It has single circuit brakes.
 I was adjusting slack and my helper did a heavy apply and both rear stayed applied. Fronts were retracted but not rears. Cracking a chamber line its still got pressure.  Eventually it drains off and chambers retract.
This valve has three mounting holes.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
Offline buswarrior
Re: 4106 brake relay valve
« Reply #1 on: February 18, 2022, 06:39:34 PM »
Call Luke at US Coach and it will be on the way with your credit card.
Good catch, finding that lazy relay valve!!!
Happy coaching!
Buswarrior
Offline Boomer
« Reply #2 on: February 19, 2022, 08:26:24 PM »
DD-3's not releasing?  Try a couple more applications.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
Vancouver, WA USA
Offline richard5933
« Reply #3 on: February 20, 2022, 04:29:02 AM »
Didn't think that the 4106 had DD3 brakes. Have these been changed?
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #4 on: February 23, 2022, 02:22:47 AM »
Richard -
DD3 brakes were an option on late production 4106s.
Fortyniner -
Luke's number, if you don't have it already, is 1-888-262-2434
FWIW & HTH. . .  ;)
Offline chessie4905
« Reply #5 on: February 23, 2022, 07:16:25 AM »
I guess first, how many hoses connected to each brake chamber? Two or three?  Can't see from here.
Offline buswarrior
« Reply #6 on: February 23, 2022, 11:22:16 AM »
How did this stray onto DD3?
OP has identified a lazy releasing relay valve, and said it has 3 mounting holes...
Winter fever is setting in...
Happy coaching!
Buswarrior
Offline chessie4905
« Reply #7 on: February 23, 2022, 02:33:12 PM »
yes they do and both type chambers use same relay valves, possibly different model. mine uses r6
