Author Topic: Stud welding  (Read 3644 times)
Offline windtrader
Re: Stud welding
« Reply #15 on: February 22, 2022, 10:36:47 AM »
One other option to provide secondary, redundant securing is to run a strap, cable, whatever over the top of the panels and secure to the gutters on each side.
Aesthetically, some may not like the strap but it blends in well due to the location of the panels, the roof contour, and location and distance of the gutter to the panel
Until I redid the bracing, I used straps and they held things fine temporarily. The gutters are plenty strong and able to take the load.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Offline Dave5Cs
  • BCM Subscriber
Re: Stud welding
« Reply #16 on: February 22, 2022, 10:40:27 AM »
Did you add a tail so they will fly better next time. :)
Offline windtrader
Re: Stud welding
« Reply #17 on: February 22, 2022, 10:49:12 AM »
They flew just fine. Took right off like a jet, nice nose dive into the roadway too. got a gift on that failed experiment.
Don F
Fully converted
Bought 2017
Offline freds
  • 1980 Prevost Original Motorhome
Re: Stud welding
« Reply #18 on: February 22, 2022, 12:42:05 PM »
Make sure you don't cover any silicon as it only takes a minor shadow to cut the power output...
Offline windtrader
Re: Stud welding
« Reply #19 on: February 23, 2022, 08:39:28 AM »
Fred. Yes, good idea. I think every panel is installed on rails so added straps can lay over them. Panels could still detach from the rails but that should be less of an issue if attached properly.
Don F
Fully converted
Bought 2017
