BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
crank pulley
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: crank pulley (Read 1909 times)
BUR
Full Member
crank pulley
on:
March 31, 2022, 02:47:56 PM »
Will the front crank pulley off of 8V71 fit on a 8V92
Logged
1980 Prevost 8V92 HT754CR
Homebase Yuma AZ
Vantaré Conversion "Miss Vivian"
Hero Member
Re: crank pulley
Reply #1 on:
March 31, 2022, 09:49:01 PM »
The 8V92 has a huge vibration dampener for it's crank pulley.
Logged
Hero Member
Re: crank pulley
Reply #2 on:
April 01, 2022, 07:54:16 AM »
Quote from: BUR on March 31, 2022, 02:47:56 PM
Lot of variations on DD pulleys post a photo ,if it is hub mounted it will work,the pullleys are mounted on the outside of the vibration damper which is mounted on a hub on the crank
Logged
MC8Mike
Full Member
Re: crank pulley
Reply #3 on:
April 01, 2022, 08:24:05 AM »
Yeah they fit, I used my 8v71 pulley on my 92.
Logged
1973 MC8 in progress. 8V92TA, HT740D, Ross Steering. Fallon, Nevada
Hero Member
Re: crank pulley
Reply #4 on:
April 01, 2022, 08:34:34 AM »
The front of the crank is same size the 12v71 and the 8v92 use the same vibration damper fwiw
Logged
BUR
Full Member
Re: crank pulley
Reply #5 on:
April 01, 2022, 11:55:25 AM »
Thanks Clifford, been trying to get in touch with you. Wilbur
Logged
Homebase Yuma AZ
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
crank pulley
