Author Topic: Coleman Roof Top AC Units  (Read 24629 times)
« on: July 14, 2023, 08:36:57 AM »
Where are you guys buying the roof top AC,since Thor owns Coleman now the Mach 8 plus are imposable to buy every place is on backorder and prices have doubled .I need the the Mach 8 I am not interested in any other brand ,the Mach 8 + will cool in 125 F degrees and is low profile I need for a H-40 Prevost
Offline David Anderson
  • just outside San Antonio TX
Re: Coleman Roof Top AC Units
« Reply #1 on: July 14, 2023, 01:19:57 PM »
They show they have them but I would verify with a phone call for sure.  It seems everyone else is showing backorder.
You're right about the price.  It has doubled.  I knew it wouldn't get better when Thor bought them out.
David
https://onlinervsupply.com/products/coleman-mach-8-rooftop-air-conditioner-ultra-low-profile-rv?currency=USD&variant=43058935070912&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&gclid=EAIaIQobChMIkqvd-oCPgAMVKAGtBh2qTwK3EAQYBSABEgKVKPD_BwE
« Reply #2 on: July 14, 2023, 01:40:51 PM »
David
Thanks David they have 1 for ducted use I need non-ducted without the condensation pump
Offline tr206
Build back better not working we need to make American great again. Lets go Brandon!
« Reply #6 on: July 15, 2023, 06:31:17 AM »
They may have one since they are asking twice the price of other sellers the 240v rating is a ? for me though
Offline tr206
« Reply #7 on: July 15, 2023, 10:47:42 AM »
If you got the money honey they got the a/c.
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #8 on: July 15, 2023, 11:06:43 AM »
Did you call John Zahn. Because you have an active subscription with BCM, you will qualify for 10% off any order over $50.  714.703.8200
https://www.rvpartscenter.com/
Offline windtrader
« Reply #9 on: July 16, 2023, 08:56:03 AM »
capacity is dependent on input power/voltage. I think 12k is about the max on 120v.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
« Reply #10 on: July 16, 2023, 09:03:12 AM »
15,000 btu Colemans do good on 110v,Coleman makes a 2 compressor unit maybe those are 240v
Offline tr206
« Reply #11 on: July 17, 2023, 04:15:15 AM »
« Reply #12 on: July 17, 2023, 04:29:30 AM »
Not long a go it was cheaper to toss the unit and replace it not now ,I am going to replace the motors and call it a day.The motors cost as much now as the unit cost 2 years ago lol the news says inflation is over  :-\
Offline Jim Blackwood
« Reply #13 on: July 17, 2023, 06:47:51 AM »
It mostly depends on the seer rating. At one time we thought a seer over 10 was very good. Now it appears that a few of the mini-split units are advertising a seer of 36. That is 3.6 times as efficient as the old seer 10.
Why does that matter? Simply because if your seer 10 unit at 12K btu draws 15 amps of full current load a 36 seer 15K btu unit would pull 4.2 amps. Meaning at least theoretically that a 15 amp circuit could support a 36K btu unit on 115v. We are not seeing those on the market but that doesn't mean we won't. It just requires a mini-split manufacturer to recognize the market potential and build one. Somebody should suggest it to the Chinese.
Or maybe to the Almish. Ted, how about your buddies up in Napanee? You think they would be interested?
Offline chessie4905
« Reply #14 on: July 17, 2023, 06:48:21 AM »
Spend the extra money for the heavy duty version. Thicker tubing and heavier duty components.
