Author Topic: MCi part number for differential piñon shaft seal gasket plate  (Read 8074 times)
Offline cutnhorse
Looking for the correct part # for the gasket that bolts on to the differtial housing that holds the pinion seal my book shows its 2f-3-19 nfi says that's a shim, don't have any anyone know where to get them, is this the correct #
Re: MCi part number for differential piñon shaft seal gasket plate
« Reply #1 on: August 17, 2023, 06:13:52 PM »
That is a Rockwell shim pack, type in Rockwell PS+2 shim pack it takes 3 minimum or they leak those packs go up to PS+6 have idea how thick your were ? they are part of the adjustment
Offline cutnhorse
« Reply #2 on: August 18, 2023, 09:25:40 AM »
 Saved my old shims but there was a gasket with them, does that kit come with the gasket, that's the only way to get it, do you know what series of Rockwell differential that is?
« Reply #3 on: August 18, 2023, 11:09:39 AM »
Rockwell used the shim packs on dozens of model of the single reduction gear
Offline chessie4905
« Reply #4 on: August 18, 2023, 04:03:16 PM »
Get gasket paper, and a ball pein hammer and make one. Easy peasy.
